EAGLE User Chat (English) Special Pin One
  • Subscribers 187 subscribers
  • Views 450 views
Special Pin One
I have indicated in the design rules that I want pin 1 on DIP packages to be
square.  I have saved this one change in the default design rule file, and I
have loaded it in my test board editor screen.  But nothing happens.  Is
this supposed to automatically produce a square pin on all library DIP
parts?  What am I doing wrong?
Eagle is pretty darn mind numbing....
Also, is the DRC just guidance, or will it actually change things like
distance from board edge?  I have to frequently place pads and traces pretty
close to the board edge.  I do not mind it showing me I have violated the
rule, but I sure do not want it changing anything!
Syd H. Levine
AnaLog Services, Inc.
Phone:  (270) 276-5671
Telefax:  (270) 276-5588
E-mail:  analog@logwell.com
Web URL:  www.logwell.com
    analog wrote on Sat, 12 December 2009 18:10
    to be
    and I
    Is
    There are options in the DRC dialog about this.  The default is probably
    "as in library", which is why you don't see anything.  It's probably better
    to make this change in the library anyway.  Overriding things after a
    package has been designed is a kludge.
    Try reading the manual instead of blaming the tool.
    Yes.
