EAGLE User Chat (English) Need MRF406 and MRF454 package
  • Subscribers 187 subscribers
  • Views 311 views
I have to rebuild a PCB from 1991 that uses a RF transistor of the above
type's.
I know the package and trying to build it myself but no luck as the package
has some lines under a 45 degree angle.
It may sound stupid but i cant the package drawn in Eagle as i dont know how
to draw a part of a circle under 45 degrees with the correct size.
The question to the group is does anyone these packages for RF transistors
or knows how to draw these.
Harry
    type's.
    package has some lines under a 45 degree angle.
    how to draw a part of a circle under 45 degrees with the correct size.
    transistors or knows how to draw these.
    Harry
    Hi Harry
    Thanks for using a newsreader directly into the forum.
    There is a package already in Eagle that looks close.
    Search for a MRF136. It's in the transistor-fet library. That is built
    with a package that should be a good start for you. Confirm the size is
    correct to your own satisfaction.
    All the best
    Warren
