EAGLE User Chat (English) Auto-place routine that works?
  • Subscribers 187 subscribers
  • Views 911 views
Just bought a 7.1 license and taking it for a test drive. I found three
auto-place ULPs in the download section but none of them seems to work.
Maybe because they were for older Eagle versions.
Is there an auto-place routine somewhere that works with V7? Ideally
where one can place critical parts like RF stuff and connectors, then
let the auto-placer drape the rest around.
Regards, Joerg
    Joerg wrote on Wed, 26 November 2014 15:18
    No.  That's the problem.  This is not a Eagle-specific issue.
    Auto-placing in general is not a solved problem.  Some have tried to hack
    away at it, but as you see, the results aren't impressive.
    http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
    autodeskguest over 10 years ago in reply to autodeskguest
    Try my ULPs:
    http://www.eaglecentral.ca/index.php/t/52576/256be4c4206151befe797ec27fe110f7/
    They provide "unpiling".
    Try my ULPs:
    Joerg wrote on Thu, 27 November 2014 01:41
    Jorge Garcia wrote:
    We've never run into a good auto-place algorithm either, that's
    why
    we've taken the position to not dedicate developer resources to
    that.
    The ULPs you see are what's available for autoplace.
    Thanks, Jorge. That's a bit disappointing. However, we shall never
    give
    up
    You misunderstood, there will not be an autoplacer because there is not
    good solution to the problem.
    I have written three ULPs for the task of placing, they are not autoplace
    programs but they do move parts around due to their connectedness.
    They are not in a state to be released but they do kind of work.
    If you contact me I am willing to share them with you and explain how to
    use them.
    autodeskguest over 11 years ago in reply to autodeskguest
    Jorge Garcia wrote:
    On 11/26/2014 3:18 PM, Joerg wrote:
    Hi Joerg,
    We've never run into a good auto-place algorithm either, that's why
    we've taken the position to not dedicate developer resources to that.
    Thanks, Jorge. That's a bit disappointing. However, we shall never give
    up so I'll just make a sugestion in the "suggest" forum. After all a
    steady vote by some of us for a hierarchy final got us a hierarchy.
    Which was the core reason for buying V7 for me because I could not even
    properly do one upcoming project without it.
    Regards, Joerg
    Hi Joerg,
    hth,
    Jorge Garcia
