EAGLE User Chat (English) Drill Sizes
  • Replies 15 replies
  • Views 3047 views
Drill Sizes
What do the drill sizes in the menus mean?  Actual drill or plated size?  Why
are they expressed to so many decimal places?  I need a .061 hole for a staked
turret terminal; do I uese that .063xxx drill size?  I am used to seeing a
simple selection like .061 in menus of simple programs like the ExpressPCB
designer.  What do I wind up with if I just type in .061?
    I played with the "Set Drill_Menu" command, and it works fine.  You can enter
    your preferred drill list on the command line in any editor, or you can do it
    globally in the .scr file, or for each editor in the .scr file.  The project
    file overrides the .scr if you have already established a project, but I think
    it will remember changes made in the editor command window, maybe.
    Syd
    On Tue, 22 Dec 2009 13:14:44 -0500, analog@logwell.com wrote:
    Thanks so much for that helpful information.  I was thinking about using
    Advanced since they have been courting me, but I may go with AP Circuits or
    Sunstone since I do not really like the drill size spec.
    On that drill table, "Set Drill_menu" is included in the eagle.scr file under
    each editor subheading.  I have no idea if this will do what you want, but I
    noticed it was there.  Seems that it should, but things are seldom as they seem
    in Eagle...
    Syd
    On Fri, 18 Dec 2009 11:13:39 -0500, Chuck Huber <chuck.huber@dukepro.com> wrote:
    Many (but not all) board houses interpret this as the finished hole
    size.  In the case of Advanced Circuits, it's the drill hole size.  The
    plate through will take up 3-4 mils on each side of the hole.
    Why
    I haven't found out how to change it yet, but the drill sizes default to
    millimeters.  When your grid is in inches or mils, the conversion takes
    it out to many decimal places.
    You can set the hole size to anything appropriate to your need.  I've
    had to use large holes for pins that are rectangular (such as on a
    relay).  For a pin that's .050" wide, I'll add about .010 or more to
    handle the plate-through and a little tolerance for a loose fit.  So a
    hole that's .063" would be fine in this example.  The extra few mils in
    the diameter will help effect easier assembly should any pins be
    slightly bent.
    designer.
    If you find out how to set the default drill sizes, please let me know.
    I've been looking for this for a while to no avail.
    You'll wind up with either a .061 drill, or a .061 finished hole,
    depending on your board house.  When you set the drill size, you can
    also specify units.  i.e. 61mil would accomplish the same thing.  This
    comes in handy if you grid is set to a metric scale but you want to use
    English drill sizes.
    Enjoy,
       - Chuck
    in Eagle...
    Syd
    Why
    slightly bent.
    designer.
    Enjoy,
       - Chuck
  • dukepro
    dukepro over 16 years ago
    Why
    slightly bent.
    designer.
    Enjoy,
        - Chuck
    It is written in pidgin English.  I can't change that and have mo inclination to
    pretend it is anything it is not.  Perhaps you do not know what a pidgin
    language is since you equate my observation with the sucks comment.
    I am trying to use the program, and have run into many problems.  I am not
    trying to make any friends in Europe,  Besides, if I was inclined to try to
    influence anybody, which I am not, I would be talking to the big shots at
    Newark.
    Fortunately there is a Yahoo group for Eagle where the members are nice folks
    and genuinely helpful.  These Cadsoft Usenet newsgroups seem to be made up of
    folks who worship Cadsoft, and useful answers are in short supply.
    All that being said, I like the program and will be using it to do our boards.
    And thanks for the lecture on what Americans need to learn; it says volumes
    about you.  I will advise the State Department immediately of your words of
    wisdom so they will behave more in accordance with your wishes.
    On Thu, 17 Dec 2009 00:07:37 -0500, James Morrison <james@eaglecentral.ca>
    wrote:
    analog wrote on Wed, 16 December 2009 23:00
    >Quote:
    and not to expect much from the sadly written documentation,
    including the help screens.
    >There you go again.
    There I go again?  Without a doubt Eagle has the worst documentation I
    have seen
    for a major piece of software in a decade or more.  It is written in
    pidgin
    English in a strange idiom, and is woefully incomplete.  The so-called
    documentation sucks badly (I use so-called here as it is used in the
    manual in
    describing aliases, a wholly inappropriate descriptor).  Are you
    telling me I am
    wrong, and that the manual is a brilliant piece of work?  Or are you
    telling me
    I must not complain about something I paid actual money for and that
    does not
    meet expectations?  The latter would be downright un-American!
    Let me see if I can inject some sanity here.  Remember, Christmas is coming
    Sure you can complain.  But if you want to actually exert influence then
    perhaps you could consider your tone.
    Statements like "pidgin English" and "sucks badly" aren't exactly going to
    endear you to the ones who actually make the software.  If I was them, I'd
    simply add your name to the kill file and never see another post you make
    again.  No one wants to read that about something they put a lot of time
    into.  I'm not saying they are doing it but that's what I'd do.  There are
    enough people making good suggestions in constructive ways that I don't
    need the verbal abuse.
    It is true that if you are a native English speaker you can tell that some
    of the English has been translated from another language.  But not always
    and it's not that bad, really.  I'm not saying the documentation is a work
    of art, but whenever I need to use it my questions are answered most times.
    If it's not, I'll ask here and Klaus or someone else at CadSoft will
    respond and if necessary they'll update the next version of the docs.
    Maybe if you presented your ideas in a more constructive way people might
    actually want to listen--and respond.  I have a lot of things to do in my
    day.  I'm happy to answer a question if I have a minute for someone
    searching for an answer.  But if I know the conversation is going to turn
    nasty then I won't bother.  So if you want help in the future then take a
    pill and relax.  Even if all of your suggestions were gold that no one else
    had thought about it is still going to be a best case of 6 months to a year
    before they get implemented and released.
    And as for un-American, this isn't an American board.  It's in english but
    it's a global village here.  There are other ways to win on an issue other
    than guns a-blazing.  Perhaps something that Americans need to learn in
    general--hey you brought it up image
    And remember, let's all find some peace in our lives this Christmas.
    Cheers,
    James.
    email:  james@eaglecentral.ca
    web: http://www.eaglecentral.ca
    Specialising in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    >Quote:
    >There you go again.
    have seen
    pidgin
    manual in
    telling me I am
    telling me
    does not
    Cheers,
    James.
    There you go again.
    There I go again?  Without a doubt Eagle has the worst documentation I have seen
    for a major piece of software in a decade or more.  It is written in pidgin
    documentation sucks badly (I use so-called here as it is used in the manual in
    describing aliases, a wholly inappropriate descriptor).  Are you telling me I am
    wrong, and that the manual is a brilliant piece of work?  Or are you telling me
    I must not complain about something I paid actual money for and that does not
    analog wrote on Wed, 16 December 2009 16:26
    I don't buy that it is somehow a problem to complain about annoyances.
    If I
    have offended you, I am sorry.
    There is big a difference between a reasoned discussion about why you think
    a feature is undesirable and a childish emotional outburst simply whining
    about it.
    Quote:
    Is it a serious problem, or a real problem at all?  Probably not.
    Exactly.  Just type in whatever size you want.  That's quicker than
    selecting it from a list with the clickety-click interface anyway.  As I
    mentioned, I wasn't even aware the drop down menu had all those fraction
    digits because I haven't found a situation where its more useful than just
    entering the desired value directly.
    Quote:
    One caveat would be to be prepared for some odd
    behaviors,
    Just like any large and complex piece of software, with Eagle being no
    exception.
    There you go again.
    I don't buy that it is somehow a problem to complain about annoyances.  If I
    I ran into the large number of decimal place thing while creating my own custom
    libraries.  It is nutso, no matter what kind of smiley face you want to paint on
    it.  Is it a serious problem, or a real problem at all?  Probably not.
    I want to make it clear that I like Eagle and would recommend it to others in my
    industry with certain caveats.  One caveat would be to be prepared for some odd
    behaviors, and not to expect much from the sadly written documentation,
    On Wed, 16 Dec 2009 13:41:54 -0500, Olin Lathrop <eagle@embedinc.com> wrote:
    analog wrote on Wed, 16 December 2009 12:06
    and made unfounded assumptions about my attitude.
    Try not complaining, instead ask why with a open mind.  Deciding something
    is "ridiculous" and "nutso" before getting all the reasons behind it is a
    unproductive attitude and will annoy those you seek help from.
    In any case, complaining to fellow users is pointless since there is
    nothing we can do about it even if we did agree with you.
    I just tried a experiment in Eagle.  I did a CHANGE DRILL to see the list
    of sizes that I think you are so offended by because they were listed with
    lots of digits.  Then I did SET and went to the DRILL tab and defined a
    custom size like 20mil.  That showed up in the list as ".02" as expected.
    However, when I went back to CHANGE DRILL, this size didn't appear in the
    list.  I thought that's what the SET drill-tab was for, but apparently
    there's more to it than that.
    Whether that's a bug, or more likely, my misconception due to not having
    read the help on the subject, I don't think it's a problem either way.  I
    wasn't even aware of the many decimal places since there is very little
    reason to ever do a CHANGE DRILL and then pick a size from the drop down
    menu.  Drill sizes for thru hole pads belong in the libraries.  Drill sizes
    for vias  should come from the net class with some input from the DRC
    settings.
    There are only two cases I can think of right now where you'd enter a drill
    size manually.  One is when you're manually routing.  Eagle doesn't seem to
    default the drill size from the net class as perhaps it should.  Second is
    if your board needs other holes, like for mounting.  In both those cases
    I've always just typed "cha drill xxx".  You know the size you want, so
    it's quicker and easier to just enter it than fumble around in a dialog
    looking for it or something close.
    settings.
    Like I said, Usenet is dying for good reason.  Where I come from the original
    responder was rude and made unfounded assumptions about my attitude.
    Cadsoft says we see all those ridiculous drill size digits when viewing in
    inches because the program thinks in millimeters, and they want to guarantee
    accurate conversions.  Problem is the grid is in inches, so it has to be
    converted to millimeters to begin with.  Yes, the world is metric, but pin
    spacings are still done the good old Americun way.  So, the long string of
    decimal places on some of the inch drill sizes is in fact nutso, aside from
    violating sig fig sensibilities.  Does it matter? Not much, but it is
    unappealing to anyone with an engineering background.
    As they say in Get Shorty, "You don't know me, you just think you do".
    First of all, you are the one with a less than stellar attitude here.
    You asked a question and it was answered. Correctly, if I may say so.
    I come in here for advice, and you flame me.
    The answer to you question was certainly not a flame. It was in fact
    polite and factually correct.
    Since I paid cashey money for my copy, I have a right to ***.
    Again with the attitude. Tone it down a notch or two. You might get
    better report with people.
    OK, I'll bite, what is a remotely rational explanation for the long drill sizes?
    You can choose a size from the list, or you can enter a size directly.
    What's to explain about it?
    Once again: the actual drill size you have to specify depends on your
    board house. They are in charge of plating and miscellaneous tolerances.
    In Eagle you specify the final drill size. Your board house may very
    well need a number that is not the actual drill size.
    Bob
