EAGLE User Chat (English) Used Power instead of Supply on parts
  • Subscribers 187 subscribers
  • Views 556 views
I have my schematic all done and have discovered that I should have used
Supply for ground connections to some of the ICS.  ERC comes up with an
error in places where I connected Vss to GND.  Do I need to go back and
correct every part or can I just ignore the ERC warnings?
John Bachman, W1JGB
AnaTek Corporation
    John Bachman wrote on Sat, 19 December 2009 07:17
    To clarify: When creating new components one can choose the type of
    pin.
    Actually it's called the pin "direction".  Apparently when you said "used
    Supply for ground connections" you really meant "set the pin direction of
    ground pins to Supply".  This was not clear.
    Quote:
    For all pins that are power supply or ground I chose "Power".
    Here's a heretical thought: Use the pin directions as intended and clearly
    documented.  The Supply pin direction is for pins that produce supply
    rails, like the output of a voltage regulator or a ground symbol.  Power is
    for pins that are expected to be connected to a supply rail, like Vdd and
    Vss pins of a CMOS chip.
    Quote:
    It appears that Eagle would be happier if I chose "Supply" for the pins
    that I will connect to a ground.
    No, you should use Supply for the single ground symbol and Power for the
    ground pins of the various parts connected to the ground net.
    Again, this is all clearly documented.  Try HELP PIN.  It may correct a few
    more unfortunate guesses.
    On 12/18/2009 2:41 PM, Olin Lathrop wrote:
    John Bachman wrote on Fri, 18 December 2009 12:54
    used Supply for ground connections to some of the ICS.
    I don't understand what you mean by "using Supply for ground
    connections". You need to connect the ground pins to whatever net you
    want them connected
    to.
    Quote:
    ERC comes up with an error in places where I connected Vss to GND.
    Eagle complains when the net name connected to a power pin doesn't match
    the pin name. Even worse, it will automatically connect a unconnected
    power pin to a net of the same name. Argh!!
    Make sure all power pins are explicitly connected in the schematic, then
    "approve" the ERC errors complaining about a name mismatch between the pin
    and the net. Unfortunately you have to pay attention because there could
    be a real error lurking in the pile of nuisance warnings.
    To clarify: When creating new components one can choose the type of pin.
      For all pins that are power supply or ground I chose "Power".  It
    that I will connect to a ground.  Hence my question which I think that
    another poster has answered.
    John Bachman, W1JGB
    AnaTek Corporation
    Pin direction "supply" is for those pins that provide power, like within
    the GND and VCC symbols. The name of a net connected to that pin will
    implicitly taken from the pin name (if possible).
    Pin direction "power" is for those pins that need to be connected to a
    power source, like the power supply pins of ICs.
    ERC will warn you if you connect different supply pins to one net (which
    can only have one name, so that's a conflict). ERC will also warn you if
    you don't connect the correctly named net to a power pin of any device.
    Besides that, only the net names and their connections are really
    relevant. You might as well remove all power supply symbols and just
    name your nets correctly (take care of implicit power gates!).
    If you use different IC families with the same supplies, ERC will always
    report many warnings, since the power pins of the devices are named
    differently (i.e. GND, VSS or V-) but are connected to a single net.
    You can safely ignore these warnings as long as you know that these
    connections are really wanted in your design.
    Tilmann
    used
    I don't understand what you mean by "using Supply for ground connections".
    You need to connect the ground pins to whatever net you want them connected
    to.
