EAGLE User Chat (English) Out of the Box Gripes
  • Replies 24 replies
  • Subscribers 189 subscribers
  • Views 1714 views
Hello everyone,
EAGLE is quite powerful and flexible.  But with great flexibility comes
great irritation if you don't know how to do it (or even that you can).
And new users may either get discouraged and leave the community, work
inefficiently for years and not realise it, or even worse, not realise an
easy to fix issue and get back boards that don't work (thinking of cam job
mirroring of bottom layer).
So what is on your list of things that EAGLE could configure better out of
the box.  I'm not talking about any new functionality.  I'm thinking about
things that EAGLE will do, but is just not configured out of the box.  Or
things that everyone does the first time they install EAGLE.
Here's a start, please add to it.  This is meant to make EAGLE even better,
not just annoy people, so try to be constructive image  Hopefully the new
people at Newark will take this list seriously as it greatly effects that
first impression new users get.  A bad one and they might never come back.
1)  bill of materials and x-y data generation integrated, documented, and
supported.
2)  advanced find integrated, documented, and supported
3)  better use of colour pallette and default values other than indices
16-63 being gray (or grey if you like)
4)  default CAM jobs mirror bottom layer, shouldn't be done normally
5)  key assignments for all normal activities, documented and supported.
Of course, users can make their own changes by editing eagle.scr etc, but
again most users don't really know that is possible.  And a template
document that you can edit to give new employees the cheat sheet.
That's a start, I'm sure there are a ton more.
Cheers,
James.
email:  james@eaglecentral.ca
web: http://www.eaglecentral.ca
Specialising in CadSoft EAGLE
  • Electronic Design Services
  • EAGLE Enterprise Toolkit
    I just thought of another one, this may be fixed in V5 but in V4 the
    save date/time of the drawing info box does not  update from the text
    "Not saved !!!" when you save the drawing, it must be refreshed
    manually. quite misleading.
    good summary Travis, between you and James you got most of my gripes.
    That nonstandard labeling of tools is a biggie. the manual isn't really
    en-US usage either, but i think it can be understood by most.
    btw, I do use COPY! which should be called DUPLICATE or CLONE, all the
    time! Because it takes so long to add components, I make a palette of
    common ones and use COPY (sic) to add them into the schematic.
    the EAGLE "backwards" point and click interface wouldn't be backwards if
    it were clear that the tool palettes are not buttons that execute
    commands but rather tools that ( in normal windows ui ) attach to the
    cursor and are applied to objects. of course, some of them really are
    command buttons... oh well, if you pick up a brush tool in paint, the
    cursor becomes a paintbrush.
    James Morrison Inscribed thus:
    The whole point of this is that the more intuitive and documented
    EAGLE is to use, the easier it will be for new users to choose EAGLE
    as their CAD tool of choice.  That means more people will (eventually)
    upgrade to a paid license and inject money into the company.  In turn,
    in a perfect world, that means more development is done and more
    features are added to EAGLE, it continues to get better, and we all
    benefit.
    And the more things that work ouf of the box the less questions we get
    here about the very basic stuff.  New users are less frustrated and
    the SNR of the group goes up even higher.
    Cheers,
    James.
    This should be obvious !
    But it needs restating every now and then !
    As we get more familiar and comfortable with Eagle we tend to forget the
    teething pains we endured to get where we are now.
    Everybody is different and needs some hand holding at some point along
    the path.
    Best Regards:
                         Baron.
    johannes kotz wrote on Sun, 03 January 2010 11:31
    to James Morrison: Since years, I'm using my own eagle.scr. So, why
    don't you make your personal Eagle GUI like me. I really like this way to
    personalize Eagle.
    Sure, that's fine.  And I do the same.
    But the whole point of this thread is that when you first install EAGLE you
    don't know how to do that.  And there are some functions that I would think
    (as a new user) are so integral to design that the tool should support them
    out of the box in a very obvious, documented, and supported way.
    Consider this scenario:  You are a small startup company.  You have a
    limited budget and a real product you need to get to market as soon as
    possible in order to start realising income and make the business viable.
    For a CAD tool a team leader does his research and comes to two options:
    EAGLE and Tool A.  He installs EAGLE freeware to evaluate and try to design
    a small board.  This person is looking at how easy it is for his team to
    get up and running with a new tool.  For every function that he has to (if
    he even could) write or research his own ULP that is adding to the learning
    curve and initial cost.
    Now he loads Tool A and gets an eval license.  Sure it only runs on Windows
    and sure it's more money out of the box.  But it does include all the
    things he was looking for in a very integrated way that is documented,
    integrated, and supported.  If he has an issue he can call the company
    support line up and get answers.  And sure there is a maintenance cost but
    he doesn't care about that now.  If they get to market they'll have cash to
    spend, if not then they won't pay.
    Now you tell me which way he is going to go.  If it takes a week to go
    through EAGLE and set it up so that the rest of his team can use it then at
    $100/hour (not unreasonable) that's $4000.  The difference in cost between
    EAGLE and Tool A is less than $4000.  And he's not confident he can even
    make EAGLE do what he wants (because he's new remember!).
    To me that's a no-brainer.  You choose Tool A.
    The whole point of this is that the more intuitive and documented EAGLE is
    to use, the easier it will be for new users to choose EAGLE as their CAD
    tool of choice.  That means more people will (eventually) upgrade to a paid
    license and inject money into the company.  In turn, in a perfect world,
    that means more development is done and more features are added to EAGLE,
    it continues to get better, and we all benefit.
    And the more things that work ouf of the box the less questions we get here
    about the very basic stuff.  New users are less frustrated and the SNR of
    And my apologies to the females in the group.  The above person in the
    example just happened to be male.  Could have been female too, it's just
    how it came out of my brain as I wrote it.
    Cheers,
    James.
    Travis G wrote on Sun, 03 January 2010 14:09
    1)The Cut command not doing a cut.
    5)I didn't understand why I should use a net vs a wire and learned it
    wrong... I still use wire for everything...
    Yeah, don't you just love it!?  CUT does a copy, and copy never does
    anything you actually want.  Lines are drawn with WIRE unless they
    represent wires, then they are drawn with NET.  Duh.  Eagle gets a lot of
    things right, but simple stuff like bad naming detracts from the whole
    thing.
    By the way, using WIRE for schematic wires is very bad.  You really want to
    use NET, else Eagle may not understand the connectivity.
    When I first tried Eagle, I didn't understand certain things, but for
    the most part, it was much easier to learn that OrCAD. I was a PCB
    layout newbie at that point, but now I have enough experience that I
    have no problems doing dense 2-layer boards or boards with high currents
    or dealing with PCB thermals for SMT power parts (linear v-regs, FETs,
    etc). I haven't learned matched impedance traces yet...
    The biggest problems I had when I started were:
    2)I didn't know that I should create my own library and copy parts from
    eagle's lib to mine so that upgrades of eagle wouldn't affect my
    modifications.
    3)I didn't understand how to search parts / packages in the library. I
    still don't like how the lib has to be "used" before you can search it
    and that you can't search the lib from the control panel.
    4)I had trouble finding standard components in the lib, like supply and
    gnd points, and didn't know about the pageframes at all for a long time.
    6)I didn't learn what Smash did for a while. It was a case of Didn't
    know didn't care, till I learned what it did! LOL
    7)Knowing that I shoul use Vector fonts for the PCB wasn't something I
    learned for a long time, not until I started doing small PCBs and the
    text kept running off the board.
    8)Using Polygons for GND and Vcc planes. That would have been nice to
    know a lot sooner than I learned about it.
    Other than those few minor things, I found it to be an easy program to
    learn and began doing working PCB layouts very soon after starting to
    use it.
    Now I usually fine the getting started things useless... But a tips and
    tricks page, those can be useful even for experienced users.
    Olin wrote on Sun, 03 January 2010 10:23
    James Morrison wrote on Sat, 02 January 2010 21:41
    But more than a ULP, it needs to be more integrated into the GUI,
    IMHO.
    Argh, no!  Not anymore at least.  Whatever they do is going to be
    incompatible with what I do now.
    to Olin: I totally agree, everyone should be able to make 'his own eagle'
    to James Morrison: Since years, I'm using my own eagle.scr. So, why don't
    personalize Eagle.
    Regards, Johannes Kotz
    But more than a ULP, it needs to be more integrated into the GUI, IMHO.
    incompatible with what I do now.  I'll be stuck either not using the new
    interface and having to explain that to new people, or wasting a lot of
    time converting libraries and some existing projects that will be
    incrementally modified.
    However, they can make attribute management a little easier, keeping in
    mind that many people are using the new attributes for BOM information.
    Propagating the same attribute for all technologies and packages for a
    device is tedious.  I finally wrote a ULP for that, but it could be better
    if built in.  Setting attributes on parts in a schematic is currently
    broken.  You can't type the attribute name and value, then click on a part
    or series of parts to apply them.  On several occasions I've ended up
    creating a script with a external editor to do this.
    Quote:
    Quote:
    There should be template CAM files for a few common board
    configurations, like 2 and 4 layer.
    Why not for all configurations?
    Because that would make it more confusing and these examples would apply
    less well to more common boards.  Once someone understands the 4 layer
    example, they can easily modify to their particular needs for more
    complicated boards.
    In general you don't want go too far creating the impression that things
    are easier than they really are.  Circuit design, layout, routing, BOM
    generation, and getting boards fabbed takes specialized knowledge and
    skill.  So does using whatever tools aid in this process.
    You want to make Eagle seem accessible, but going too far takes resources
    from the real issue of making it better.  It seems the quality of the real
    documentation of large software tools is inversely proportional to the size
    of the getting started guide, which is of little use once you've gotten
    started.  Remember when you could read the documentation with MS Word like
    a manual to see what it can do and get some intuition on how it works?  Now
    all you can do is ask specific question without learning what else is
    possible or how the system thinks inside, all the while with that stupid
    paper clip in your face that says "we think you're so dumb that we can give
    you a silly animated icon instead of real documentation".
    Eagle isn't really that hard to learn if you just RTFM, like most packages.
    Anyone that can't handle that and wants instant gratification instead has
    no business desinging circuits, or doing any other engineering for that
    matter.
    This page elevated me from a rank newbie to a mere beginner:
    http://claymore.engineer.gvsu.edu/~steriana/Videos/
    I got more here in 30 minutes than hours spent in trying to follow the
    documentation. Googling for tuts got me there.
    Martin
    "James Morrison" <james@eaglecentral.ca> wrote in message
    news:hhp0e9$tjc$1@cheetah.cadsoft.de...
    James Morrison wrote on Thu, 31 December 2009 16:59
    Hello everyone,
    of the box.  I'm not talking about any new functionality.  I'm thinking
    about things that EAGLE will do, but is just not configured out of the
    box.  Or things that everyone does the first time they install EAGLE.
    Just to follow up and encourage new users to comment, as this is really
    addressed to them.  For us who've been using the tool for ages it's
    difficult to look at things from a different perspective.  What did you
    think of EAGLE the first time you tried it?  What would have made it
    easier?  What would have made a better impression?
    Cheers,
    James.
    Hello everyone,
    Cheers,
    James.
