EAGLE User Chat (English) Out of the Box Gripes
  • Replies 24 replies
  • Subscribers 189 subscribers
  • Views 1668 views
Hello everyone,
EAGLE is quite powerful and flexible.  But with great flexibility comes
great irritation if you don't know how to do it (or even that you can).
And new users may either get discouraged and leave the community, work
inefficiently for years and not realise it, or even worse, not realise an
easy to fix issue and get back boards that don't work (thinking of cam job
mirroring of bottom layer).
So what is on your list of things that EAGLE could configure better out of
the box.  I'm not talking about any new functionality.  I'm thinking about
things that EAGLE will do, but is just not configured out of the box.  Or
things that everyone does the first time they install EAGLE.
Here's a start, please add to it.  This is meant to make EAGLE even better,
not just annoy people, so try to be constructive image  Hopefully the new
people at Newark will take this list seriously as it greatly effects that
first impression new users get.  A bad one and they might never come back.
1)  bill of materials and x-y data generation integrated, documented, and
supported.
2)  advanced find integrated, documented, and supported
3)  better use of colour pallette and default values other than indices
16-63 being gray (or grey if you like)
4)  default CAM jobs mirror bottom layer, shouldn't be done normally
5)  key assignments for all normal activities, documented and supported.
Of course, users can make their own changes by editing eagle.scr etc, but
again most users don't really know that is possible.  And a template
document that you can edit to give new employees the cheat sheet.
That's a start, I'm sure there are a ton more.
Cheers,
James.
email:  james@eaglecentral.ca
web: http://www.eaglecentral.ca
Specialising in CadSoft EAGLE
  • Electronic Design Services
  • EAGLE Enterprise Toolkit
  • kcadsoft
    kcadsoft over 16 years ago
    On 01/19/10 15:45, Klaus Schmidinger wrote:
    On 01/19/10 14:38, James Morrison wrote:
    Klaus Schmidinger wrote on Tue, 19 January 2010 04:45
    On 01/18/10 23:29, James Morrison wrote:
    I'll add to my list:
    New board files have the DRC setup as (1*16) but there are 16
    layers
    displayed in the layers.  That is not correct and confusing.  If
    you put
    anything on those layers you get a DRC error (rightly).  And to get
    rid of
    them you have to change the layer configuration to something else
    (1*2+16)
    for instance and then back to (1*16) to get the layers displayed to
    only
    show top and bottom.
    And during routing you get the whole list of layers to switch
    between when
    the DRC setup says there are only two layers and it should just
    toggle.
    This bug must be overwhelming to new users who aren't quite sure
    how things
    should work and what to do about it.   And it's a nuisance to
    experienced
    users to boot.
    I can't reproduce this here.
    When I create a new board, the DISPLAY, LAYER, ROUTE and WIRE command
    all
    show only layers 1 and 16.
    Let me be a bit more specific.  If I go from Control Panel and create a
    board with File->New->Board then the layers are as I expect.  But I rarely
    use this path in reality.
    First create a new schematic from Control Panel with
    File-New->Schematic. Then I type in "board" and answer "Yes" to the
    dialog to create a new
    board.  Now there are 16 electrical layers shown in layers dialog even
    though the DRC->Layers setup is (1*16).
    Ah, now I see.
    Will be fixed.
    Fixed for version 5.7.1.
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    Klaus Schmidinger wrote on Tue, 19 January 2010 09:45
    the
    even
    Ah, now I see.
    Will be fixed.
    Great.  Thanks Klaus.
    James
  • kcadsoft
    layers
    you put
    rid of
    (1*2+16)
    only
    between when
    toggle.
    how things
    experienced
    users to boot.
    all
    Ah, now I see.
    Will be fixed.
    Klaus Schmidinger
    layers
    you put
    rid of
    (1*2+16)
    only
    between when
    toggle.
    how things
    experienced
    users to boot.
    all
    First create a new schematic from Control Panel with File-New->Schematic.
    Then I type in "board" and answer "Yes" to the dialog to create a new
    Quote:
    Is there something in your eagle.scr file that might display all
    layers, like "SET USED_LAYERS ALL"?
    There is no instance of "LAYERS" at all in eagle.scr.
    Cheers,
    James.
  • kcadsoft
    New board files have the DRC setup as (1*16) but there are 16 layers
    displayed in the layers.  That is not correct and confusing.  If you put
    anything on those layers you get a DRC error (rightly).  And to get rid of
    them you have to change the layer configuration to something else (1*2+16)
    for instance and then back to (1*16) to get the layers displayed to only
    And during routing you get the whole list of layers to switch between when
    the DRC setup says there are only two layers and it should just toggle.
    This bug must be overwhelming to new users who aren't quite sure how things
    should work and what to do about it.   And it's a nuisance to experienced
    users to boot.
    When I create a new board, the DISPLAY, LAYER, ROUTE and WIRE command all
    Klaus Schmidinger
    autodeskguest over 16 years ago in reply to autodeskguest
    James Morrison wrote on Sun, 03 January 2010 03:45
    I think you're onto something.  Whenever I have to use a CAD tool I'm
    not familiar with the first thing I do is google for a cheat sheet for
    it.  That would be of great advantage to new users.  Once you get over
    that first hurdle and see how EAGLE handles its commands it gets a lot
    easier.  A one-sheet 8.5x11 (or A4) page could include everything you
    need to know to get started.
    Anyone know of a good cheat sheet? I tried to google for it, but I couldn't
    find any. I did find this thread though... image
    Stig
    users to boot.
    James.
    "James Morrison" <james@eaglecentral.ca> wrote in message
    news:him006$1d9$1@cheetah.cadsoft.de...
    Terri Miller wrote on Fri, 08 January 2010 12:13
    "James Morrison" <james@eaglecentral.ca[/email]> wrote in message
    news:hhj6ri$urt$1@cheetah.cadsoft.de...[/email]
    <snip>
    *CAM jobs mirroring bottom side layers by default.
    <snip>
    This was fixed in 5.7!  Thanks to CadSoft for listening.
    James.
    Yes... thank you CadSoft!
    Terri
    <snip>
    <snip>
    James.
    Hello everyone,
    better,
    supported.
    Cheers,
    James.
    Hello James,
    I am listing some of the sames 'gripes' as have been listed already, but
    just wanted to give some input about what I experience with customers.
    *Vector font output - confusion about being about to design with
    proportional or fixed font, but only outputs vector.
    *Stacked pad issue - When the name of the layer contains the $ character,
    pads and vias need to be deselected during output.  If not, it creates a pad
    and clearance in the same spot.
    As far as documentation, it may not be a bad idea to have a list of errors
    (with screenshots) and some explanation on how to resolve the issue.  For
    example, 'Invalid Polygon' error for files created in older versions of
    EAGLE; 5.0 now recognizes the invalid polygons, while older versions do not.
    And another off the top of my head, 'Polygon may cause extremely large plot
    data'... when the polygon width is too small.  There are more, but these
    come to mind right now.
    I know that the answers can be found in the documentation and/or help menu,
    but having the list would save tons of time on searching and hoping that the
    search terms that you are using are correct.
    That's all I have for now!
    Best regards,
    Terri
