EAGLE User Chat (English) Editing "paste-mask layer"??
  • Subscribers 187 subscribers
  • Views 1032 views
I am adding a test connector, with contacts made between board pads and
spring loaded pins.  To ensure pads will make good electrical contact,
the manufacturer cautions the "past-mask layer" be corrected defined.
I find no reference to that name in the EAGLE manual.
Does it have another name?
How can I be sure the contact pads will be solder paste free?
Manufacturer notes:
CAE/CAD packages usually assume that pads with no through holes are for
surface mounted components and solder paste is deposited on them by default!
To resolve this, edit the pad-stack in your CAE/CAD software, show the
paste-mask layer and set the pad size to zero for that layer.
Ken
    Olin,
    Thanks!
    Ken
    Olin Lathrop wrote:
    Ken wrote on Mon, 04 January 2010 11:25
    Having solder on the pads is not necessarily a bad thing.  Solder is soft,
    and allows the point of the pogo pin to dig in a little without harming
    anything.
    What you really want is to make sure there is no solder mask on the pad,
    since that is deliberately a insulator.  However, both the solder mask and
    paste mask are separate layers in Eagle.  You can chose separately for each
    layer whether it will cover the pad or not.  Look at layers bStop and
    bCream.
    Quote:
    Manufacturer notes:
    default!
    I guess they really don't want solder on the pads.  You adjust this with
    the bCream layer (or tCream if the pad is on the top side).  Normally you
    would make a device in a library for that, which has the appropriate layers
    all set.
    anything.
    bCream.
    Quote:
    Manufacturer notes:
    default!
    all set.
