EAGLE User Chat (English) Text logo on layer 1
  • Replies 8 replies
  • Views 839 views
blewis999
blewis999 over 16 years ago
I have tried to use the import-bmp.ulp that takes a bit map and places
it on layer 200 and 201 but my results were poo. I could not get a a
black and white (2 bit) color map from the font/screen capture/
conversion. It seems that Windows adds a lot of grey tones to edges to
get the fonts; even though I only used black and white in the text.
Does anyone know a better way to create a logo, or even just text, or
to overcome the grey/non black and white pixel problems.
Robert
    autodeskguest over 16 years ago in reply to autodeskguest
    I figured it out. Even though I only had 2 colors in MSPaint, unless you
    specifically set it to B&W (Image/Attributes/Black & White) , you get some
    flag that tells the world it isn't. After doing that, it imported fine!
    Thanks for your interest!
    Ron
    Attach your .bmp and we can have a look to see if there is an issue with it.
    Warren
    "Ron Anderson" <rona@benchforge.com> wrote in message
    news:hsafni$ej4$1@cheetah.cadsoft.de...
    I, too, am trying to create a Logo on a board using "import-bmp.ulp",
    however I keep getting an error message saying that the BMP has more than
    256 gray levels. That's impossible. I used GIMP to posterize it to 1-bit
    (black & white). I also tried setting the threshold to 2, and that didn't
    work either.
    Enough other folks here seem to not have a problem. What could I be doing
    wrong?
    work either.
    wrong?
    Robert Lewis schrieb:
    Thank you for the reply; can you recommend any free software that does
    this please? I haven't worked with this type of software.
    As Christen already noted, even Paint can do that.
    There are /many/ free software packages for image processing:
    examples are Paint.Net, FastStone, IrfanView, GIMP, ...
    Pick one that fits your needs and is comfortable. I prefer FastStone,
    but for more complicated things I also use two different (commercial)
    software packages - you probably heard of Photoshop before (which is one
    of them)...
    Tilmann
    P.S. Please fix your quoting order. Thanks.
    Paint in Windows can save-as black/white bmp. Might be ok.
    You do not use the saved file, but need to save it anyway, to make the
    conversion.
    I use GIMP for this.
    It is free and works well but also has a lot of other features.
    Maybe too many if that is all that you are going to do.
    "Robert Lewis" <robert.lewis@iMnMicroControl.com> wrote in message
    news:qrapk5pk5cmdqihoq11935hao14btk0muv@4ax.com...
    Robert
    On Tue, 12 Jan 2010 16:52:57 +0100, Tilmann Reh
    Use an image processing software to reduce the image to 1 bit per pixel
    (b/w) before importing.
    Tilmann
  • blewis999
    Robert
    Tilmann
    Tilmann
