EAGLE User Chat (English) Creating a ground plane
  • Replies 9 replies
  • Views 1410 views
I have finished creating the board layout except all the GND wires.
What I want is that all the free place on the board will be part of the GND
ground plane.
How should I do that?
Harry
    "Morten Leikvoll" <mleikvol@yahoo.nospam> schreef in bericht
    news:hjc7bi$baa$1@cheetah.cadsoft.de...
    "Harry H. Arends" <info@time-tech.eu> wrote in message
    news:hj9s3i$s5g$1@cheetah.cadsoft.de...
    Next problem, I have text on the bottom where the ground plane should
    come.
    How can I create a clear rectangle around that text. If I create a poly
    around the board the text is still there but completely enclosed.
    This is a bit different from porpotional fonts and vector fonts.
    Propotional fonts seem to make a nice square window, but that only shows
    up if you print (not plot) the layer.
    Vector fonts does add spacing around the text, but not in a window. You
    can draw a square (using wires) in the restrict layer close around the
    text. You may get fills inside it if the window is much bigger than the
    text and orhphans=on on the polygon. Play with it a bit and do ratsnest
    each time to change something.
    Solved the problem by placing a restrict on the text that is slightly
    smaller.
    After a ratnest it places a nice square around the text.
    come.
    Propotional fonts seem to make a nice square window, but that only shows up
    Vector fonts does add spacing around the text, but not in a window. You can
    draw a square (using wires) in the restrict layer close around the text. You
    may get fills inside it if the window is much bigger than the text and
    orhphans=on on the polygon. Play with it a bit and do ratsnest each time to
    change something.
    or you can put the letters (vector font) into the bRestrict layer and
    they will be copper free in the poly.
  • dukepro
    dukepro over 16 years ago
    On 01/21/2010 10:39 AM, Jim Littlefield wrote:
    news:hj9ial$81r$1@cheetah.cadsoft.de...
    come.
    poly around the board the text is still there but completely enclosed.
    It depends on what layer you put the text in and how your CAM job
    outputs.    If the layer that the text is in is output as part of the
    bottom silkscreen then it will not interfere w/ the pour since the
    silkscreen will be printed on top of the metalization.
    If you are trying to put text into the same layer as the ground pour
    then the letters in the text will automatically be isolated from the
    plane just like vias, pads, etc.
    If you want a nice rectangle around the text, you can draw draw a
    rectangle on the bRestrict layer that encloses the area occupied by the
    text to prevent the copper pour from filling that area.  This will
    produce DRC errors since the text itself is within the bRestrict area.
    Once these errors are marked as approved DRC will not bother you again.
    Enjoy,
        - Chuck
    news:hj9dsa$hon$1@cheetah.cadsoft.de...
    That works, but where do I determinate the distance between the
    polygon and its surrounding tracks and pads.
    If I draw a polygon around text will it leave that area not filled?
    Global settings is in the DRC window (clearance tab, wire-via/
    wire-wire number (Polygon is a wire-fill)). Rerun ratsnest after
    changing DRC settings.
    If you need a bigger clearance for a single polygon, look in the
    polygon properties. Here you can select isolate, but it has to be
    greater than DRC clearance setting, orelse DRC settings will be used.
    Read help/manual a bit on polygons. There are other issues you need to
    know about if you have overlapping polygons, and wire width of
    polygons also matter in how it is filled.
    Next problem, I have text on the bottom where the ground plane should come.
    That works, but where do I determinate the distance between the polygon
    Global settings is in the DRC window (clearance tab, wire-via/ wire-wire
    number (Polygon is a wire-fill)). Rerun ratsnest after changing DRC
    settings.
    If you need a bigger clearance for a single polygon, look in the polygon
    properties. Here you can select isolate, but it has to be greater than DRC
    know about if you have overlapping polygons, and wire width of polygons
    settings.
    Read help/manual a bit on polygons. There are other issues you need to know
    about if you have overlapping polygons, and wire width of polygons also
    news:hj9b64$6ef$1@cheetah.cadsoft.de...
    news:hj9ail$3p3$1@cheetah.cadsoft.de...
    GND ground plane.
    Draw a polygon around the edges of the board. Then name it "gnd". Press
    ratsnest to fill it.
    That works, but where do I determinate the distance between the polygon and
    GND ground plane.
