EAGLE User Chat (English) VUNREG Poly in GND Poly
  • Subscribers 187 subscribers
  • Views 418 views
I have a polygon named GND with a simple track init called VUNREG.
Now I wanted to make it bigger so I thought using a polygon that follows the
VUNREG track and name it also VUNREG.
But that doesn't work. Isn't is possible to create a Polygon inside a
Polygon?
    the VUNREG track and name it also VUNREG.
    Polygon?
    A polygon inside a polygon needs a different rank. Help polygon (rank is
    almost at the bottom) image
    Gruß / regards
    Joern
