EAGLE User Chat (English) mechanical layer in eagle layout
  • Subscribers 187 subscribers
  • Views 1129 views
Hi all,
Great job for all the help you've been providing thus far. I work with a lot
of mechanical engineers, often my board layout files have no dimensions on
them. How do I display dimensions, distances with eagle layout and generate
a file that the ME guys can use to make an enclosure or design around the
board.
Thanks in advance for your help.
regards,
vadryn
    Yes...use dxf.ulp
    vadryn P wrote:
    Ok, If I understand from my research, it should be a function of using a
    dxf.ulp file. Is that correct or is there more to it.
    thanks
    vp
    "vadryn P" <vadrynpierre@gmail.com> wrote in message
    news:hkbl58$34j$1@cheetah.cadsoft.de...
    Thank you all for the input. I tried exporting the brd file as dxf, it
    gave me option for net list and a bmp image file. I apologize for my
    ignorance and I will further consult the manual for further guidance. Up
    til this point, I don't know how to export as dxf, though it seems to be
    common knowledge in this post. I am happy to learn from anyone willing to
    elaborate some simple steps.
    sincerely yours,
    vadryn
    "Gary Gofstein" <nospam@use.forum.net> wrote in message
    news:hk7fdo$k0q$2@cheetah.cadsoft.de...
    there is a ULP "adimv4_0" that can be downloaded that puts dimensions
    around the board. i use it but don't like it much.
    a better solution is to export the dimension as dxf and pull the
    dimensions out of it in your mechanical CAD program.
    there are also some tools that generate 3D representations of the board
    to use in CAD systems. search the forums for the ongoing discussion of
    them.
    thanks
    vp
    sincerely yours,
    vadryn
    them.
    Thank you all for the input. I tried exporting the brd file as dxf, it gave
    me option for net list and a bmp image file. I apologize for my ignorance
    and I will further consult the manual for further guidance. Up til this
    point, I don't know how to export as dxf, though it seems to be common
    knowledge in this post. I am happy to learn from anyone willing to elaborate
    some simple steps.
    sincerely yours,
    vadryn
    there are also some tools that generate 3D representations of the board to
    use in CAD systems. search the forums for the ongoing discussion of them.
    to use in CAD systems. search the forums for the ongoing discussion of them.
    vadryn P wrote:
    Hi all,
    board.
    regards,
    vadryn
    You may also want to look at the 3rd party product Eagle PCB Power
    Tools.   You can download it from the downloads area but needs a licen$e
      for the measures to work.   I eventually bought and used this package
    for some of my designs.   It took a bit if fiddling to get things to
    work the way I wanted but it definitely does generate dimension lines.
      One of the tools will automatically generate dimension lines "..for
    all visible objects..".   You have to be a little careful which layers
    are turned on when you generate the dimensions or you will get a real
    mess!
    Caveats about the tool (from my limited experience)
    1.  The dimension lines don't automatically update if you move them around.
    2.  I could find no way to edit the length of a dimension line manually
    3.  If you change the size or relative position of things the dimensions
    don't automatically move around so you have to clear out the dimension
    layer and then re-run the tool.
    Generating a dxf is a good solution (included w/ Eagle already) and
    gives a more complete definition of the mechanicals ... but the mech-e
    has to actually load up the dxf and measure things!
    Jim
    board.
    There are no automatic metrics with EAGLE.
    I use the "measures" layer (47) to draw guidelines and sizes in it - all
    manually. However, since these are normally very few I can live with that.
    For your "ME guys" you might also do an export to DXF - normally they
    are lucky with that. Just export all mechanically relevant layers
    (dimension, milling, eventually measures).
    Tilmann
