EAGLE User Chat (English) edit the pin design
  • Replies 12 replies
  • Subscribers 187 subscribers
  • Views 1496 views
edit the pin design
Do you know if there is a possibility to edit the library pin design ?
For design and aesthetics reasons I would like smaller text for the pin name
and number.
Jerome
    and number.
    The implicitly generated pin names and numbers have fixed sizes. You can
    however turn them off (in the symbol) and then use text objects instead
    - but you lose flexibility for changes, since these names and numbers
    won't be automatically updated any more.
    I got used to the implicit sizes meanwhile...
    (The same applies to distance and orientation if the pin names.)
    Tilmann
    Jerome wrote on Tue, 09 February 2010 10:07
    Yes.  I'm sure lots of people do.
    name and number.
    So go ahead.
