EAGLE User Chat (English) Device with no package?
  • Views 564 views
Can someone direct me to the manual section that describes how to create
a device with no package?  I am working on an rf design that has a pc
track antenna.  I need to show the antenna on the schematic (connected
to a balun).
John Bachman, W1JGB
AnaTek Corporation
  • dukepro
    dukepro over 16 years ago
    On 02/11/2010 04:27 PM, John Bachman wrote:
    I was thinking of making the footprint out of copper also but could not
    figure out how to do it.  Guess I am missing something (nothing new).
    I've had to do similar tasks in the past.  In the package layout, I
    added an SMD pad (or TH pad) to represent the antenna center conductor.
    I then added a copper trace from the pad out to a length and width
    appropriate to the frequency.  Round the end caps as necessary for your
    design.
    If you wanted to place an on-board dipole, you can do the same thing for
    the other antenna lead.
    You can also position the SMD pad along the copper trace to add some loading
    A DRC error will be produced for the area where the SMD pad overlays the
    copper trace.  Once approved, it never bothers you again.
    Enjoy,
        - Chuck
    On 2/11/2010 4:21 PM, Gary Gofstein wrote:
    I was thinking of putting the antenna copper pattern as the footprint,
    but if you just have a sort of sham footprint that enables you to get a
    pad on the board, then yeah, you can draw a poly and name it to the net.
    In EAGLE, polygons always fill with copper afaik. The trick is that they
    must be named to the netname they connect to.
    If you were to draw a polygon in the footprint itself, I believe you
    will get a DRC error, it's one of the things that's annoying about
    EAGLE. But you know, as long as the Gerber's correct, it doesn't matter.
    If you could make the antenna pattern out of pads, it wouldn't complain.
    John Bachman, W1JGB
    AnaTek Corporation
    On 2/9/2010 5:14 PM, Gary Gofstein wrote:
    It's possible, but not with the use of pins that you can wire to in your
    schematic device...how about making the antenna copper the footprint
    (package)? Otherwise, you must just make a symbol and put sham wires for
    schematic connection.
    I have created a footprint package and created an antenna device using
    that footprint.  I presume that the next step is to add the device,
    position it on the board and then draw a polygon around the outline and
    pour copper into the polygon?
    John Bachman, W1JGB
    AnaTek Corporation
