EAGLE User Chat (English) Eagle3d v1.05
  • Replies 8 replies
  • Views 1433 views
Eagle3d v1.05
I just installed a newer version of Eagle3d.
But now if i create a new pov file and render it i get this message:
Messages cleared.
Preset INI file is 'C:\PROGRAM FILES\POV-RAY FOR WINDOWS
V3.6\RENDERER\QUICKRES.INI', section is '[1280x1024, AA 0.3]'.
Preset source file is
'C:\Users\h.arends\Documents\Eagle\povray\HEADERS_MALE_FEMALE.pov'.
Redirecting Options
  All Streams to console..........On
  Debug Stream to console.........On
  Fatal Stream to console.........On
  Render Stream to console........On
  Statistics Stream to console....On
  Warning Stream to console.......On
Parsing Options
  Input file:
C:\Users\h.arends\Documents\Eagle\povray\HEADERS_MALE_FEMALE.pov (compatible
to version 3.61)
  Remove bounds........On
  Split unions.........Off
  Library paths:
    C:\Program Files\POV-Ray for Windows v3.6\INCLUDE
    C:\Windows\Fonts
    C:\Program Files\EAGLE_5\eagle3d\povray
    C:\Program Files\EAGLE_5\eagle3d\inc
    C:\PROGRAM FILES\POV-RAY FOR WINDOWS V3.6\include
Output Options
  Image resolution 1280 by 1024 (rows 1 to 1024, columns 1 to 1280).
  Output file:
C:\Users\h.arends\Documents\Eagle\povray\HEADERS_MALE_FEMALE.bmp, 24 bpp
(system format)
  Graphic display......On  (gamma: 2.2)
  Mosaic preview.......Off
  CPU usage histogram..Off
  Continued trace......Off
Tracing Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 3
  Light Buffer.........On
  Vista Buffer.........On   Draw Vista Buffer....Off
  Antialiasing.........On  (Method 1, Threshold 0.300, Depth 3, Jitter 1.00)
  Clock value:    0.000  (Animation off)
File: C:\Program Files\POV-Ray for Windows v3.6\INCLUDE\glass_old.inc  Line:
18
Parse Warning:  Due to changes in version 3.1, you must add interior
to all objects calling glass_old.inc textures and
finishes...
File: C:\Program Files\POV-Ray for Windows v3.6\INCLUDE\tools.inc  Line: 63
File Context (5 lines):
#declare col_gold = texture {T_Gold_5E finish{F_MetalA ambient (0.35 *
global_ambient_mul
Parse Error: Expected 'numeric expression', undeclared identifier
'global_ambient_mul' found instead
Total Scene Processing Times
  Parse Time:    0 hours  0 minutes  0 seconds (0 seconds)
  Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Render Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Total Time:    0 hours  0 minutes  0 seconds (0 seconds)
CPU time used: kernel 0.31 seconds, user 0.35 seconds, total 0.66 seconds
POV-Ray finished
Could someone explain to me why this is happening?
  • gmail
    gmail over 7 years ago in reply to autodeskguest
    Tuan Matthias ....
    bagaimana Anda menggambar yang begitu indah, bagus dan rapi?
    Bisakah Anda berbagi cara membuat file makro di bawah -Eagle 3d povray
    autodeskguest over 7 years ago in reply to gmail
    On 8/01/2019 3:03 PM, Sunandir Osing wrote:
    Master Matthias
    Eagle 3d povray rendering is very good and realistic image, but, how do I make a macro inc file under eagle 3d povray .... can you help me ...
    https://www.element14.com/community/message/270186
    This tutorial may help you.
    http://d1.amobbs.com/bbs_upload782111/files_9/ourdev_195292.pdf
    HTH
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
  • gmail
    Master Matthias
    The seconf line from below generates the error:
    #if(inc_testmode=true)
            #declare pin_short = on;
            #declare pcb_height = 1.500000;
            #declare pin_length = 2.5;
            #declare global_res_colselect=1;
            #declare global_res_col=1;
            #declare global_res_shape=1;
            #declare global_res_bend_radius=1;
            #declare global_diode_bend_radius=1;
            #declare global_seed=seed(1234);
            #declare global_show_screws = on;
            #declare global_show_washers = on;
            #declare global_show_nuts = on;
            #declare global_ambient_mul = 1.0;
    #end
    #declare besch_font = "courbd.ttf"
    global_ambient_mul)}};
    #declare col_silver = texture {T_Silver_5A finish{F_MetalA ambient (0.35 *
    global_ambient_mul)}} ;
    "Matthias Weißer" <matthias@matwei.de> schreef in bericht
    news:hlei4r$pcs$1@cheetah.cadsoft.de...
    Harry H. Arends schrieb:
    That is correct. Files created with the old version, don't know the
    version
    sorry, are ray traced correct.
    Files created with the new 1.05 version create problems.
    I think POVRay find the .inc files which are delivered with a older
    version of Eagle3D before the current versions. Please check you
    installation. Maybe you have copied the Eagle3D .inc files to your
    POVRay directory.
    Matthias
    I just downloaded the installer from your website and ran it.
    Are there some point i should look after?
    version
    POVRay directory.
    Matthias
    That is correct. Files created with the old version, don't know the version
    POVRay directory.
    Matthias
    news:hl32su$b7u$1@cheetah.cadsoft.de...
    global_ambient_mul
    I expect you have a version problem between 1.05 and a release candidate
    of 1.10.
    Matthias
    global_ambient_mul
    of 1.10.
    Matthias
