EAGLE User Chat (English) Assigning buttons.
  • Subscribers 187 subscribers
  • Views 510 views
Assigning buttons.
I don't know why I haven't done this before, I've got a G11 keyboard with 18 extra buttons
to the left of the keyboard, I noticed it's alot more comfortable than reaching for the F-keys.
I've got the keys assigned to all commands I use except the middle mousebutton feature,
what is the command middle mouse button use?
I can of course just assign a key to Layer 1 and another to Layer 16, but I really want the same key
being able to switch back and forth...
Does anyone know?
Cheers
//Greg.
    As I see it you will need to assign the key to run a small ULP that
    toggles
    the active layer between layer 1 and 16.
    The command to change the layer while routing is LAYER #. If you use
    CHANGE
    LAYER # it will terminate the routing which is not what you want.
    Warren
    Woops! A ULP will not be useful while routing as running it will terminate
    the routing.
    "Greg" <ash_4@gravitywell.org> wrote in message
    news:hlhdch$uhf$1@cheetah.cadsoft.de...
    18 extra buttons
    Does anyone know?
    Cheers
    //Greg.
    As I see it you will need to assign the key to run a small ULP that toggles
    The command to change the layer while routing is LAYER #. If you use CHANGE
    Warren
    Ash wrote on Wed, 17 February 2010 13:43
    I think it's CHANGE LAYER.
