EAGLE User Chat (English) Via's sometimes one, sometimes two
  • Subscribers 187 subscribers
  • Views 417 views
My board is two sided.  When I add a via I sometimes get two of them.  I
can move either one around independently of the other.  When making
connections (top and bottom) they are both connected to one via, not the
other.
What is going on here?
John Bachman, W1JGB
AnaTek Corporation
    John Bachman wrote on Wed, 17 February 2010 15:40
    I can move either one around independently of the other.  When making
    other.
    In addition to what User said, check how the layer stack is defined in the
    DRC.  It should be just layer 1 and 16.
    other.
    How do you add those vias? Do you know that EAGLE automatically adds a
    via every time you change the routing layer (during the routing process,
    as well as when changing the layer of a track segment afterwards), so
    you normally don't need to add vias manually (except for special
    situations).
    If the problem persists, please post a "recipe" about how to reproduce
    it. Don't forget to mention relevant details like grid settings etc.
    Tilmann
