EAGLE User Chat (English) Drill holes greater than 3.2 mm
  • Subscribers 187 subscribers
  • Views 433 views
I am a newbie of eagle.. please how is it possible to make a drill hole more
of 3.2 mm ?
thanks.
    of 3.2 mm ?
    thanks.
    You can do this several ways...
    1. Click on the info button, select the hole, and the properties display
    dialog enter whatever diameter you want, then click apply.
    2. Use the change tool (looks like a little wrench), Change->diameter,
    and select the diameter you want from the list (or add a new diameter to
    the list) then click on the origin of the hole(s) you want to change.
    of 3.2 mm ?
    grid mm;
    hole 3.3
    Tilmann
    P.S. Learn to use the command line.
