EAGLE User Chat (English) How to mulitiply board ?
  • Subscribers 187 subscribers
  • Views 311 views
I've created small board from schematic. Now I want to multiply it (5x1
matrix) into larger board for automated mounting of 5.
During cut group / paste into another board problem appears. New, added
  boards have
parts enumerated so silk screen description shows i.e. no  5xR1 (as I
expect) but R1, R2, R3, R4, R5 instead. After board mounting and
separation I want to have 5 same boards with the same parts description.
How to disable multiplied parts enumeration or get problem work around
(beter solution than "text" command for every part)?
Przemek
      boards have
    This can't be "disabled" - every part must have its unique identifier.
    But there's a solution though: Run one of the panelize ULPs, before
    actually doing the panelizing. They create copies of the part names in a
    separate layer. Then, when generating the gerber files, use that new
    layer instead of tNames/bNames.
    Tilmann
