EAGLE User Chat (English) re-use library symbols
  • Subscribers 187 subscribers
  • Views 385 views
I'm trying to re-use a NPN transistor libary symbol in Eagle 5.7.0
The manual states 'cut ( 0 0);' after defining a group with all layers on,
and 'paste into the same or another library' - how does that work?
I tried the cut several times, but how and where can I paste it.
I made a .lbr file in my home with the new transistor name, how can I
insert a NPN symbol into it and carry on.
TIA
Denis
    You would create your new symbol by selecting symbol in the library and
    entering the name that you want to use.
    It will then confirm to create the symbol. You can then select paste and put
    it where you want. Likely at the origin.
    I have found the easiest way to copy between a library or libraries is to
    open the destination library and then navigate to the source library in the
    control panel.
    Then you can drag a device, package or symbol into the target library.
    If you just want to reuse a a symbol in the same library then you do not
    even need to copy it, rather just call it from the device editor.
    "Denis Casserly" <fprckq@shaw.ca> wrote in message
    news:hm3ptr$rb3$1@cheetah.cadsoft.de...
    I'm trying to re-use a NPN transistor libary symbol in Eagle 5.7.0 The
    manual states 'cut ( 0 0);' after defining a group with all layers on, and
    I tried the cut several times, but how and where can I paste it. I made a
    TIA Denis
    dcassyc1 wrote on Wed, 24 February 2010 13:07
    You can draw a new symbol or copy one from another library.  You can copy
    packages, symbols, and devices from another library with the COPY command.
    See HELP COPY for details.
