EAGLE User Chat (English) High-count mating cycles card edge connector?
  • Subscribers 187 subscribers
  • Views 4424 views
Anyone know a manufacturer of card edge connectors that guarantees a lot of
mating cycles? A typical PCI express x16 connector guarantees only 50
cycles (Tyco 1746220-1)
I want to make a jig for pcb bringup and testing and I want to plug a lot of
pcb's into it.
Maybe there a some specialized pinching connectors out there?
    pcb's into it.
    Another approach: add a separate connector between the card edge
    receptacle and your test environment. Then you can simply replace that
    "adapter" every time the contacts are worn out.
    For that interface connector I'd suggest VME type connectors (german
    standard DIN 41612), they are specified for 500 mating cycles and in
    practice are /far/ better. If your PCIE connector lasts for about 100
    cycles, you'd be able to test at least 50000 boards... (Of course you'd
    wear out several of the PCIE connectors for that.)
    Tilmann
    oh yeah, just remembered, i think these only work for low to modest
    current ranges. oh well.
    if possible, add your own test connector, 50 cycles is pushing it for
    any card edge. you can leave the test connector off the BOM when you
    make alot of them.
    the only other alternative I can think of is to make a test jig, I would
    use a flexible "pink link" rubber connector to bridge the gap between
    edge contacts on two boards ( three if edge is double sided w/2
    connections per pin position ). these things are really ZIF and only
    require being compressed evenly to work well. usually used to contact
    LCD panels>.
    one manufacturer, there's probably more:
    http://www.fujipoly.com/design/default.asp
    pcb's into it.
    Perhaps you can contact the DUT by some other means, like spring contact
    probes? There are ones with round top which wouldn't even scratch the
    gold finish of the PCB contacts. Example:
    <http://www.ptr-messtechnik.de/en/produktuebersicht/federkontakte/detail_fk.php?id=5>
    Of course, it's some effort to build a test fixture - but that will be
    very reliable then.
    Tilmann
    Morten Leikvoll wrote on Fri, 26 February 2010 09:12
    lot of
    mating cycles?
    Bare conductive fingers on a board are not good for many insertions.
    Perhaps there is such a thing as a board edge ZIF connection, but I've
    never seen one.  I suppose you could make one from pogo pins and your own
    jig.
    I have seen card to bus connectors intended for lots of cycles.  These do
    not use fingers on the board, but a actual connector that mates with a
    connector on the bus board.  The ones I've seen looked like little two
    prong forks at each end, and they fit into each other at 90 degrees.  I
    have no idea what they were called.  I haven't seen such thing in many
    years.
    "Morten Leikvoll" <mleikvol@yahoo.nospam> wrote in message
    news:hm8ksc$ha0$1@cheetah.cadsoft.de...
    of mating cycles? A typical PCI express x16 connector guarantees only 50
    of pcb's into it.
    Hi!
    No, there isn't.  image
    I once faced a similar problem. In the company, we used a smal adapter pcb
    with another socket. That makes 50 times 50 cycles which sums up to 2500. We
    needed 1000 cycles and a board lasted about 70. Some vendors do advertise
    special connectors with thicker gold layers on their webpages, but you are
    unable to buy them. It's only vaporware.
    Carsten
