EAGLE User Chat (English) Off board components
  • Replies 11 replies
  • Views 1151 views
I've been working my way through all the example projects I found on the
Cadsoft site, wow... They are useful.
Because I want to develop good habits from  the start and I'm trying very
hard to unlearn some very awkward techniques I bring from the "other"
commercial software I was using, so I really appreciate any advice you can
give me.
I want to show off PCB components on the schematic, like a panel mounted
pot, or switch, or jack because I want them to be included in the bill of
materials.
So, what is the preferred method to do this? I see most just leave them off
the schematic and use a connector or pads for the off board stuff.
In the "other" software, I created some panel components that just had pads
for the PCB package. It worked OK.
Are there already some "off board" components like this? I've tried every
keyword I could think of to search the libraries, but no luck yet.
Thanks for you patience with a new user.
David
    that's my method as well. If eagle were a hierarchical "tree"
    environment it would be unnecessary. but it's not. bottom line, there is
    no good, easy, supported way to do this in EAGLE. so it's a workaround.
    Travis G wrote on Mon, 01 March 2010 10:13
    #usage "<b>Bill Of Material</b><p>\n"
    "Generates a board's Bill Of Material.<p>\n"
      deleted to avoid clutter...
    Thanks Travis. Works like a charm.
    David
    Thank you Travis. I'd love the modified ULP. I've got enough to learn just
    using Eagle. I haven't written a line of C or C++ for 20 years. I'm saving
    ULP creation for down the road... image
    David
    email: mailto:dingebre@3dphysics.net
    web: www.CFandE.com - work
    web: www.xmission.com/~dingebre - hobby
    Here you go. The modifications are minor. Search TG in the ULP to find
    my modifications and where to add your own if you decide to exclude
    other symbols from the BOM.
    Travis G wrote on Sun, 28 February 2010 12:12
    Interesting comment Travis. Thanks
    David
    One problem is that most of the BOM creation script will not export
    those parts because they have no package. So, you can either create a
    package with no nothing in it to use as a placeholder, or, what I did
    was modify the ULP.
    The modification does create the possibility of schematic parts such as
    Vcc and GND being included in the BOM under certain situations, but
    that's easy to post-process or modify the ulp to exclude in the future.
    If you want my modified version, let me know.
    David
    David
    was modify the ULP.
    Travis G wrote on Sun, 28 February 2010 11:45
    On 2/28/2010 9:21 AM, Olin Lathrop wrote:
    dingebre wrote on Sun, 28 February 2010 05:03
    mounted pot, or switch, or jack because I want them to be included
    in the
    bill of materials.
    You have to be consistent with what a BOM is for and what a
    "board"
    means. In any place I've worked with, you wouldn't want a panel
    mount
    switch on
    the same BOM as that of the board. The board needs pads or a
    connector for
    the switch wires, so that is shown on the schematic and goes on the
    BOM for
    the board. The switch goes on the BOM of another assembly. Then
    the
    larger unit is another assembly that shows the board and the switch
    with
    cable installed onto the board as subassemblies.
    You can put a comment in the schematic explaining what is intended
    to be
    connected to the pads or connector that is on the board, but that's
    as far
    as it goes and should go. Think tree structure.
    Olin, in large work environments, that's the way it should be. However
    for someone who does smallish projects and assembly, or does it all
    themselves, it's helpful to integrate into the board's BOM so that you
    don't forget to order those parts.
    Also, for someone like me who changes things fairly often to support
    new
    features on a board, it would be hard to manage multiple sets of parts
    lists for multiple devices each with multiple versions... To stay sane,
    I have to keep it in the schematics. I actually made a part that's
    nothing but a value-label so I can "create" those things I need just by
    putting in it's part number as the value. Crude but fast and effective.
    David
    Olin wrote on Sun, 28 February 2010 07:21
    mounted pot, or switch, or jack because I want them to be included in
    the bill of materials.
    You have to be consistent with what a BOM is for and what a "board"
    means.  In any place I've worked with, you wouldn't want a panel mount
    switch on the same BOM as that of the board.  The board needs pads or a
    connector for the switch wires, so that is shown on the schematic and
    goes on the BOM for the board.  The switch goes on the BOM of another
    assembly.  Then the larger unit is another assembly that shows the board
    and the switch with cable installed onto the board as subassemblies.
    You can put a comment in the schematic explaining what is intended to
    be connected to the pads or connector that is on the board, but that's as
    far as it goes and should go.  Think tree structure.
    Thanks Olin,
    I agree with your comments for the circumstances you cite. The difference
    for me is I am doing this for my own personal use and maybe to share with
    others who have the same hobby (DIY synthesizers) (similar to the situation
    Travis describes). In that community, it is typical to include "off board"
    components on the schematic somewhere.
    However, in a "tree" frame of mind (good advice) I could do the board in
    one schematic, use pads or connectors, then do a sceond schematic only that
    shows the pot/jack/switch connections. Both schematics can be part of the
    same project. Thanks
    Carsten Wille wrote on Sun, 28 February 2010 09:48
    "David Ingebretsen" <dingebre@3dphysics.net[/email]> wrote in message
    news:hmdf0t$haa$1@cheetah.cadsoft.de...[/email]
    on the
    trying very
    "other"
    you can
    give me.
    mounted
    bill of
    materials.
    them
    off
    had
    pads
    every
    David
    Hi David,
    you can do that if you want to by drawing your own symbol that come
    without
    any pins. Ok, the symbol should look like it has some, but from eagle
    perspective, it doesn't. That enables you to generate devices without
    the
    need of packages. But you can't use the standard net command to make
    connections. By choosing special reference designators, you can easily
    separate these parts from the rest of the bom.
    Carsten
    Thanks Carsten,
    Carsten, That's an excellent way to do it and combine the on and off board
    parts in one schematic.
    mounted pot, or switch, or jack because I want them to be included in the
    bill of materials.
    switch on
    the same BOM as that of the board. The board needs pads or a connector for
    the switch wires, so that is shown on the schematic and goes on the BOM for
    the board. The switch goes on the BOM of another assembly. Then the
    larger unit is another assembly that shows the board and the switch with
    You can put a comment in the schematic explaining what is intended to be
    connected to the pads or connector that is on the board, but that's as far
    Also, for someone like me who changes things fairly often to support new
    "David Ingebretsen" <dingebre@3dphysics.net> wrote in message
    give me.
    materials.
    off
    pads
    David
    Hi David,
    you can do that if you want to by drawing your own symbol that come without
    perspective, it doesn't. That enables you to generate devices without the
    Carsten
