EAGLE User Chat (English) Off board components
  • Replies 11 replies
  • Views 1162 views
I've been working my way through all the example projects I found on the
Cadsoft site, wow... They are useful.
Because I want to develop good habits from  the start and I'm trying very
hard to unlearn some very awkward techniques I bring from the "other"
commercial software I was using, so I really appreciate any advice you can
give me.
I want to show off PCB components on the schematic, like a panel mounted
pot, or switch, or jack because I want them to be included in the bill of
materials.
So, what is the preferred method to do this? I see most just leave them off
the schematic and use a connector or pads for the off board stuff.
In the "other" software, I created some panel components that just had pads
for the PCB package. It worked OK.
Are there already some "off board" components like this? I've tried every
keyword I could think of to search the libraries, but no luck yet.
Thanks for you patience with a new user.
David
    dingebre wrote on Sun, 28 February 2010 05:03
    mounted pot, or switch, or jack because I want them to be included in the
    bill of materials.
    You have to be consistent with what a BOM is for and what a "board" means.
    In any place I've worked with, you wouldn't want a panel mount switch on
    the same BOM as that of the board.  The board needs pads or a connector for
    the switch wires, so that is shown on the schematic and goes on the BOM for
    the board.  The switch goes on the BOM of another assembly.  Then the
    larger unit is another assembly that shows the board and the switch with
    cable installed onto the board as subassemblies.
    You can put a comment in the schematic explaining what is intended to be
    connected to the pads or connector that is on the board, but that's as far
    as it goes and should go.  Think tree structure.
