EAGLE User Chat (English) Found Bug in Eagle3D
  • Views 545 views
After some days tearing my hear out on a problem with Eagle3D i found that
if the Eagle Board name starts with a number, Eagle3D will create a .POV
file but PovRay wont accept it.
Is this normal behavior for PovRay or a bug in Eagle3D.
e.g.
#if(use_file_as_inc=off)
object{
0102010BOOSTERWAGO(-37.250000,0,-50.000000,pcb_rotate_x,pcb_rotate_y,pcb_rotate_z)
#if(pcb_upsidedown=on)
rotate pcb_rotdir*180
#end
I fyou rename it to
object{  BOOSTERWAGO(-
then the file will be rendered.
Harry
    "Harry H. Arends" <info@time-tech.eu> wrote in message
    news:hn85uf$dq1$1@cheetah.cadsoft.de...
    "amelia" <silvioardito@gmail.com> schreef in bericht
    news:hmlcgv$kjt$1@cheetah.cadsoft.de...
    From POV-Ray Windows Help:
    3.2.1.1  Identifiers and Keywords
    POV-Ray allows you to define identifiers for later use in the scene file.
    An identifier may be 1 to 40 characters long. It may consist of upper and
    lower case letters, the digits 0 through 9 or an underscore character
    ("_"). the first character must be an alphabetic character. The
    declaration
    of identifiers is covered later.
    amelia
    PS. It is an half-bug of Eagle that allows an identifier with a number as
    the first character.
    After some playing around with POVRAY i created this model using EAGLE3D
    and my own created parts such as the case and screws.
    It can be found at this link: http://www.time-tech.eu/DCC/index.htm
    After some studies its not really hard to construct a povray.
    Nice work. I am a fan of Eagle 3D. Great for visualising PCBs before
    manufacture. It has saved me many times.
    I noticed you didn't have a TO220 heatsink model.
    • D03S - Heatsink
    • Written by: Greg Erskine
    • Date: 2 May 2005
    • Version: 0.01
    #macro USER_D03S(value,H_V)
        #local A = 19.5;           // width
        #local B = 10.5;           // depth
        #local C = 19.5;           // height
        #local D =  1.8;           // thickness
        #local E =  2.75;          // fin width
        #local F = (A-5*E)/4;      // gap between fins
        #local G =  4;             // hole diameter
        #local H = 14;             // hole center
        object {
          difference {
            union {
                box { <-A/2+D,0,0> <A/2-D,C,D>  }
                box { <-A/2,0,D>   <-A/2+D,C,B> }
                box { < A/2,0,D>   <A/2-D,C,B>  }
                cylinder { <-A/2D,0,D> <-A/2D,C,D> D }
                cylinder { <A/2-D,0,D>  <A/2-D,C,D>  D }
            box { <-A/2D,-1,D> <-A/22D,C+1,2D> }
            box { <A/2-D,-1,D>  <A/2-2D,C+1,2D> }
            box { <-A/2-1,C-E,D1>        <A/21,C-E-F,B+1> }
            box { <-A/2-1,C-2E-F,D1>    <A/21,C-2E-2*F,B+1> }
            box { <-A/2-1,C-3E-2F,D1>  <A/21,C-3E-3F,B+1> }
            box { <-A/2-1,C-4E-3F,D1>  <A/21,C-4E-4F,B+1> }
            cylinder { <0,H,-1> <0,H,D+1> G/2 }
            texture {pigment {Gray20}
    #end
    #macro D03S(value)
        object{USER_D03S(value,1)}
    #end
    declaration
    amelia
    After some playing around with POVRAY i created this model using EAGLE3D and
    I know, RFM. But i thought that Mathias would have build this in.
    declaration
    amelia
  • ameliaamelia
    ameliaamelia over 16 years ago
    ("_"). the first character must be an alphabetic character. The declaration
    amelia
