EAGLE User Chat (English) DRC + ULP
  • Subscribers 187 subscribers
  • Views 303 views
DRC + ULP
I want to write a ULP can cleansup board designs after the autorouter.
The first thing i want to solve is this problem:
You usually set the minimum width to the minimum of your board
manufacturer. nice for the router, but you endup with a very difficult
to produce design. i want to make a ULP that loops thrue all wires, and
makes them thicker, then runs a DRC to check for (new) errors.
Is this possible?
remco
    Remco Hosman wrote on Sun, 07 March 2010 05:53
    manufacturer.
    If you are referring to the DRC setting, then yes.  Actually I usually
    default to 8 mil width with 8 mil space, then set it smaller only if I
    really need to.  Every board house I know of can do 8/8 rules and not mess
    it up.
    Quote:
    i want to make a ULP that loops thrue all wires, and makes them
    That's definitely not the way to do it.  It won't even work in many cases.
    You really need to do HELP CLASS and read it very carefully.  That's the
    right way to get what you want.
