EAGLE User Chat (English) sequentially moving components by name in l ist?
  • Replies 9 replies
  • Subscribers 187 subscribers
  • Views 1265 views
Is there a way to list multiple components to do an operation on from the
command line...
What I'd like to do is type "move R1,R2,R3"
and then be moving r1 with the mouse, then when it's placed automatically
picking up R2, then automatically picking up R3.
Instead of having to type:
mov R1  (hand back to mouse and move R1)
mov R2 (back to mouse and move R2)
mov R3  (back to mouse and move R3)
Cheers,
Alex
    autodeskguest over 16 years ago in reply to autodeskguest
    Alex Faveluke wrote:
    A big question... is there a way to get the number of elements an array
    contains?   What I did with this is just keep incrementing the index until
    I get a NULL from the array.. which is intuitive, but scary.  You'd never
    do that in C.  Can I depend on stringarray[onepastlast] == "" ????    I
    guess
    I could also store the return linecount from fileread.
    That's what I 'd do.
    Got to bounce on the uparrow key to re-run the ULP.  I got it to call
    itself, but I can't figure out how to do multiple commands in the exit
    statement.. where the last command only executes after the "move" has been
    done.
    The command separator (image terminates the "move" before I've got a chance to
    actually move the component.  Anyways, it's still great, becuase I can hit
    uparrow/return with my keyboard hand a lot easier than typing in reference
    designators for each part.
    just assign a shortcut (help assign or via menu-options-assign)
    Out of curiousity, was the ULP language syntax derived from any other
    programming language.  It looks like C, but sure doesn't feel like it.
    besides the object stuff it's like C
    By the way, the web forum seemed to hose the whitespace/linebreaks in your
    example.. which actually was probably good for me 'cause I was forced to
    understand the control flow while putting the indents back in.
    I don't use the web forum, but the underlying newsgroup.
    Looking on my posting in the newsreader, the only lines that are
    messed-up are the trailing comments (that I always forget to keep
    under 80 chars 8-).
    Lorenz
    faveluka wrote on Sun, 14 March 2010 05:04
    Thanks for the help, here's my shot at this.
    until I get a NULL from the array.. which is intuitive, but scary.
    That's the way to do it.
    your example.. which actually was probably good for me 'cause I was
    forced to understand the control flow while putting the indents back in.
    Use the and /code structure for that.  That will use a monospace
    font and retain the whitespace.  Click on the "BBcode in on" link to the
    left of the text window for all the syntax.  I know, that is a bad name and
    will be changed soon.
    Cheers,
    James.
    email:  james@eaglecentral.ca
    web: http://www.eaglecentral.ca
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    I think it'll be pretty useful.. For example, when I want to place all
    components around an opamp, usually I'll  be looking back and forth between
    the schematic and board.. this way I'll just do the selection in the
    schematic and go.
    guess
    done.
    Cheers,
    Alex
    Thanks!
    I'm going to give it a shot.
    Alex
    Grabbing stuff from a schematic selection would be cool.  I just have to
    decide if the increase in productivity would be worth the effort to learn
    how to do ULPs... of course, then I could do ULPs for other stuff too.
    I've done scripting of course
    that's my experience too 8-)
    What would be really, really cool would be for it to listen to an external
    process that did a little voice recognition.  Is there a way to set up IPC
    in ULPs, or monitor a file?    I work next door to guys using PADs and
    voice recognition would make them turn green.  That's a reason to learn
    ULPs!
    well, no IPC that I know off, and monitoring a file from a ULP won't
    do either, because the ULP itself can't manipulate the board/schematic
    directly. It can only assemble a command string and execute it when
    terminating via 'exit()'
    Any advice on simplest possible examples of ULPs for me to look at for
    examples?
    I've attached a ULP that pics up the first part of the actual grouping
    in the schematic.
    Extending that to stash the part list in a file, getting the next part
    from the file when called from the board, and so on is left as an
    exercise to the reader 8-)
    void main ()
      string s = "";
      // when run from schematic
      if (schematic) {
        schematic(S) {                                // get the schematic
    object
          S.parts(P) {                                // iterate though
    all parts in S
            if (    ingroup(P)                        // check if part is
    in the current grouping
                 && P.device.package                  //  and has a
    package (appears in the board that is)
              if (s == "")
                s = P.name;                             // save the first
    part name for immediate use
              else {
                // stash the other part names into a file
        if (s != "")
          project.board(B) {                            // accessing the
    board when the ULP is called in the schematic
                                                      //  requires the
    project prefix
            B.elements(E) {
              if (E.name == s) {
                if (E.locked) {
                  dlgMessageBox(s + " is locked in the board");
                  exit("");
                else
                  exit("board; move " + s);
        else
          dlgMessageBox("there seems to be no actual grouping in the
    schematic");
      // when run from board
      else if (board) {
        // get the next part name from the file ...
        dlgMessageBox("to be implemented");
    Lorenz
    ULPs!
    examples?
    I do use the mov  R1 (move R1 w. mouse)  R2 ... R3... w/o having to retype
    in the mov command.
    Cheers,
    Alex
    command line...
    but you surely can create a ULP that can assist you there.
    I imagine a ULP that called with a list of part, stores the list in a
    file, then in exiting issues the move command to pic up the first part
    (letting you place it).
    On subsequent calls (via keyboard shortcut) the ULP pics the next part
    from the file and ...
    the ULP could even build the list from the current selection (group)
    in the schematic.
    Lorenz
    command line...
    Not to my knowledge...
    ...but you don't need to retype the command every time.
    I always keep my right hand on the trackball and my left hand at the
    keyboard (though I'm righthanded, I can enter the short part names
    rather quickly with the left).
    Then I do it this way:
    mov r1
    This is pretty fast and comfortable to me.
    Tilmann
    command line...
    not out of the box (as far as I know)
    Lorenz
