EAGLE User Chat (English) Need help producing 2 boards.
  • Subscribers 187 subscribers
  • Views 221 views
Greetings!
I have become too busy to finish out a project I am doing. I have 2 boards
one very small and simple with 2 components (1 smd and 1 hole through) and
a 4 pin header and one more complex with several components. I am looking
for someone that would help me get the files together so I can send them
off for manufacture. They will both be 2 sided boards and will need to
include solder mask, basic one side silk screening and holes. The designs
are simple and I can send you a circuit diagram and pdf of all the
components for measurements as needed.  I would like to start with the
small board and depending on how that goes we will work together for the
larger board. If you are interested please contact me at Jaredb)at(
Inventgeek.com and give me an estimate for the simple board.
Jared
