EAGLE User Chat (English) Changing pad size
  • Subscribers 187 subscribers
  • Views 374 views
Changing pad size
I am trying to create a pad diameter of .050" with a drill of .040".
I have copied the LED library to LED2.  I have modified the package to be
.050 dia and .040 drill.  Saved that.  Checked the measurements of the pad
and they are .050 and .040 as expected.
I then selected that library to use.
When I try to add that part to my schematic, the PCB has a pad that is .060
diameter.  I have tried modifying new parts, adding new packages and all do
the same thing.  They are correct in the library, but when I bring them into
the schematic, the dimenisons are wrong on the PCB.
Any ideas?
Thank you,
Tim
    .060 diameter.  I have tried modifying new parts, adding new packages and
    all do the same thing.  They are correct in the library, but when I bring
    them into the schematic, the dimenisons are wrong on the PCB.
    You should have a search through the older posts, I remember this being
    discussed many times. Hint: Probably a setting in DRC.
    Exactly, this is a VFAQ.
    See <http://www.cadsoft.de/faq.htm#06012601>
    Tilmann
    "Tim" <tec112@hotmail.com> wrote in message
    news:hnmfef$430$1@cheetah.cadsoft.de...
    Any ideas?
    Thank you,
    Tim
    Hi Tim,
