EAGLE User Chat (English) Polygon troubles
  • Subscribers 187 subscribers
  • Views 586 views
Polygon troubles
My design has two polygons, so far, both named GND.  Ratsnest filled in
the first one but adding another resulted in an error from Ratsnest:
"Signal GND contains an invalid polygon."
The two polygons do not touch each other.
I am stumped by this.  Any idea what I am missing?
John Bachman, W1JGB
AnaTek Corporation
    autodeskguest over 16 years ago in reply to autodeskguest
    I'm so sorry, message slip off from my fingers to this topic.
    Apologies
    :Jari
    Has anyone test is it possible to import 3'rd party components to Eagle?
    Like Analog Devices has lots of special items I wish to use, but drawing
    always these parts isnt so practical.
    Any info of importing from; multisim, orcad, protel99 and protel99PCB,
    allegro, boardstation, powerPCB and ultiboard?
    These are available from AD, but even I have ask several times support for
    EAGLE, none has appeared.
    Or does anyone know any converter to do this for EAGLE?
    Regards, :Jari
    John Bachman wrote on Wed, 17 March 2010 15:42
    Hi John,
    An invalid polygon means that two of the line segments making the outline
    of the polygon cross over each other.  This usually happens at the corners
    of complex shapes.  Go to each corner, zoom in, and drag out the corner
    until you find it.  Sometimes, it's easier to simply delete and draw
    again.
    Cheers,
    James.
    email:  james@eaglecentral.ca
    web: http://www.eaglecentral.ca
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    Frequently this means that the polygon crosses itself or has a zero length
    section.
    It should not be too hard to find if you select different areas and check
    them out.
    "John Bachman" <john.bachman@anatekcorp.com> wrote in message
    news:hnrbal$ipa$1@cheetah.cadsoft.de...
    John Bachman, W1JGB
    AnaTek Corporation
