EAGLE User Chat (English) Is it possible to arbitrarily rotate a polygon in Eagle 4.1?
  • Subscribers 187 subscribers
  • Views 812 views
I need to make 24 pours that are all the same, odd shape, but in different
places and arbitrary (i.e. not 90 deg.) orientations on my board.  It would
be nice if I could just draw the polygon once, then copy/paste/move/rotate
wherever I need it.  So far, though, I've only been able to
copy/paste/rotate (in 90 degree increments); once pasted I can't fine tune
the position with move.  SUggestions?
I CAN move and arbitrarily rotate a symbol.  Is it possible to convert a
symbol to a polygon?  Thanks.
    different
    would
    tune
    Lorenz replied:
    draw your polygon anywhere you like, then choose a reference point for
    rotation and copying and place the mark there.
    mark (x y)
    next select the polygon with the group command.
    now you can rotate it using
    rotate Rxyz (R> 0 0)
    where xyz is the angle, the > tells eagle to apply the command to the
    actual group and the R denote mark-relative coordinates.
    Now copy the polygon to the required position
    copy (R 0 0) (x y)
    picking from the mark position and placing it at x, y absolute
    Or you can do it freehand.
    The trick is to make your grid or alt grid very fine. This will give you
    fine control over the rotation.
    1. Copy the polygon
    1. Group that polygon
    2. Select Rotate command
    3. Left click and hold at your desired point of rotation on the new polygon
    and drag out from the Polygon so it goes into skeletal view
    4. Drag the mouse around to get the desired rotation.
    I would appreciate it if you could tell us what you are using the polygons
    for as I'm collecting examples of devices and applications that need custom
    pads and copper shapes.
    Warren
         mark (x y)
         copy (R 0 0) (x y)
    HTH
         Lorenz
    Karl Lautman wrote on Thu, 18 March 2010 15:44
    once pasted I can't fine tune the position with move.  SUggestions?
    HELP ROTATE
