EAGLE User Chat (English) scoring in Eagle
  • Subscribers 187 subscribers
  • Views 872 views
scoring in Eagle
I want to submit a single design to a PCB house that is actually several
separate PCBs all joined together in a mini-panel.
I've seen scoring used before so that it is easy to snap PCBs cleanly, but I
cant see how to do this in eagle.
I have seen milling layer (46), and I gess scoring is like milling except
you dont go all the way through the board.
Google hasnt come up with an answer, so I turn to you good people!
Chris
    This is nothing about EAGLE, but about communication with your board house.
    When we order scored boards, we simply draw the scoring lines in a
    separate layer (not the milling layer, since this contains our milling
    contour - normally the outlines) and provide a gerber file of that
    scoring layer along with all the other gerber files. Then we tell the
    board house to score the panel according to that file. There never has
    been any problem.
    Either that, or do it like it was done on my last smaller board: Most of
    the borders are milled out and only a few bridges remain. Then you can
    break the individual boards out like pieces of a chocolate bar.
    Hmm, where is that chocolate ... ?
    Regards, Joerg
    been any problem.
    Tilmann
