EAGLE User Chat (English) CAM processing
  • Subscribers 189 subscribers
  • Views 617 views
CAM processing
   Having trouble figuring out what layers to include for a CAM job. I'm
used to protel and am trying to learn eagle. I use 4PCB (advanced circuits)
for proto boards. When I do a CAM job for a 4 layer board i ma select the
gerber 274 4 layer job but all i get is two files. Any guidance here would
be appreciated.
Pat
    On 3/28/2010 9:38 AM, pm wrote:
    be appreciated.
    Pat
    Hi Pat,
    Hope you are doing well.
    If you look at section 9.4 in the EAGLE manual, you will find a short
    list of the gerber file types you can generate to have you're board
    made. If your board has some extra layers not covered by CAM job
    GERB274-x 4 layer, then you can simply add sections following the guides
    in the manual.
    For example let's say you need to get the stencil layer output for your
    board house. Then take GERB274-x 4 layer add a section called maybe
    "layer1 stencil" or something descriptive.
    Make sure that Output is set to GERBERS274-x then put the appropriate
    extension in the File field.
    For more details you can see the manual.
    Hope this helps.
    Jorge Garcia
    Cadsoft Computer, Support Specialist
    be appreciated.
    Pat
    You may be making the same mistake I made just a couple of weeks ago.
    When you select a "job" it is a CAM file, not the board or schematic.
    Select the CAM job that you want (AC likes the Gerber274x that I am
    using) and add the sections that you want.
    Run it and you will get a file for each section.
    A helpful person here suggested naming each section with something
    useful, like SECTION_NAME_TOPCOPPER, etc.  I found that to be a very
    easy way to keep track of which file is which.
    I sure hope that this is helpful to you as I have received much good
    help here and it sure would be nice to add some myself.
    John Bachman, W1JGB
    AnaTek Corporation
    pm wrote on Sun, 28 March 2010 08:40
    I'm
    circuits)
    the
    would
    be appreciated.
    Pat
    Hello Pat,
    If you're adding sections to a CAM job with the ADD button, it creates a
    new section and tab, copying all the stuff from the adjacent tab...
    including the output file name.  My most common mistake when making new CAM
    jobs was forgetting to change this and getting the output file from the
    first section overwritten by the next.
    Cheers,
    Alex
  • dukepro
    dukepro over 16 years ago
    On 03/28/2010 09:38 AM, pm wrote:
    be appreciated.
    Pat
    Pat,
    Look in this newsgroup for a thread called "CAM file types".  I posted a
    cam file on March 21st that we use in house for a 4-layer board.  You
    can delete "Section=" lines out of the top to accommodate a 2-layer
    board using a garden variety text editor like emacs, vim, kwrite or
    notepad (not word).
    It expects a drill file that you'll have to produce with "run drillcfg"
    Advanced Circuits likes the output, so it must be good.
    Enjoy,
        - Chuck
  • jameslittlefield
    jameslittlefield over 16 years ago
    I think maybe you click on "Process Section" button instead of "Process
    Job".
    Jim
    pm wrote:
    be appreciated.
    Pat
