EAGLE User Chat (English) Part Search for Package
  • Subscribers 187 subscribers
  • Views 1569 views
Hey Eagle people!
Anyone know if it is possible to search for packages through your
library set?
-Ethan
    Right.  I get this much.  I'm just saying that, say some avr has has a
    package named TQFP-44.  If I search the name of the part specified with
    description and library name or whatever, (mega128, etc) it'll show up
    in the results, but if I search the package name, it won't.  I'm just
    asking if there is a quick way of searching just for that.
    James Morrison wrote:
    Etharooni wrote on Sat, 24 April 2010 11:35
    The search function recognises only libraries that are in
    use (USE command).
    Sorry, I kinda forgot I posted this, so I'm coming back to it a little
    late.  I guess I wasn't clear.  I know that when I search TSSOP-8 or
    whatever into the search box, it doesn't search by package name within
    the library.  As far  as I can tell, it is only searching through the
    description.
    I think you missed this one point.  When you use the Add dialog to search
    for parts (or packages in the board editor) it will only search through
    libraries that are currently being "used".
    If you type "use *" in the command line and hit enter it will add every
    library in your library directory path (set in Control Panel) to the list
    of libraries to use.  Then the search will search through all those
    libraries.  Note that doing this will cause it longer to simply add any
    part because it has to populate the list of components in the dialog box
    and there are a lot of components in the list when you use every
    library.
    My suggestion would be to do that only when searching.  Then copy the
    device to your own library.  Under normal circumstances you only use one
    library--your custom library.
    Cheers,
    James.
    use (USE command).
    description.
    library.
    Cheers,
    James.
    email:  james@eaglecentral.ca
    web: http://www.eaglecentral.ca
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    description.
    Thanks in advance, though.
    Richard Hammerl wrote:
    Etharooni schrieb:
    Hey Eagle people!
    library set?
    -Ethan
    See http://www.cadsoftusa.com/faq.htm.en#06011302
    18. Finding Libraries and Components
    In the Control Panel's tree view Libraries branch are listed all the
    libraries stored in the given library path(s) which is set by the menu
    Options/Directories. Most libraries provide a short description of its
    content which is shown on the right half of the Control Panel as soon
    you click on one of the library entries in the tree view. Click the +
    character in front of the library name to unfold it, in order to see the
    Devices and Packages in the library. Click on one of these entries and
    you will get a preview on the right.
    In addition there is a direct search function in the ADD dialog where
    you select the components in order to place it in your schematic or
    layout. In the Schematic Editor it is possible to search for Devices.
    If you are looking for Packages, you have to do this in the Layout Editor.
    Please note: The search function recognises only libraries that are in
    use (USE command). Whether a library file is in use or not can be
    checked quickly in the Tree View's Libraries branch. If the marker
    behind the library name is green, it is in use. Is it grey, it's not in
    use and not taken into consideration by the search function.
    The ADD dialog has a Search line at the bottom. Enter the search pattern
    there. It makes sense to work with placeholders here. The asterisk *
    stands for any number of any character, while the question mark ? is
    used for exactly one single character. The options Smd and Description
    in the ADD dialog allow to extend the search for parts with smds and
    include the Device/Package descriptions.
    If you don't find an adequate part in one of the EAGLE default libraries
    take a look at CadSoft's web server. In the Download area's Libraries
    directory are lots of user-contributed files available for free
    download. Otherwise it's easily possible to define your own part in EAGLE.
  • Richard_H
    Richard_H over 16 years ago
    Etharooni schrieb:
    Hey Eagle people!
    library set?
    -Ethan
    Richard Hammerl
    Etharooni wrote on Sun, 11 April 2010 00:31
    library set?
    Yes.
