EAGLE User Chat (English) Soldermask error
  • Subscribers 187 subscribers
  • Views 277 views
Soldermask error
I am using a component with the FN40-6X6 package in the standard
libraries.  My board house reports a soldermask error on this component
- the soldermask does not completely cover the pad, the tip of the end
sticks out from under the soldermask.
How can I correct this?  Or do I even need to correct it?
I cannot see where the soldermask is defined.
John Bachman, W1JGB
AnaTek Corporation
    "Jorge Garcia" <jorge@cadsoftusa.com> wrote in message
    news:hqait0$rbr$1@cheetah.cadsoft.de...
    Hi John,
    The solder mask is defined on the tstop and bstop layers. When a board
    is made the layers define the area of the pad that needs to be exposed,
    if the soldermask doesn't cover the whole pad then your part might not
    make electrical contact resulting in a faulty board. However sometimes
    the soldermask is restricted on purpose.
    My recommendation is to check the component manufacturer's recomendation
    and adjust your mask to that.
    The size and dimensions of the solder mask can be controlled through the
    DRC setup window. Go to DRC-> Masks, here you can set how much extra
    trim the solder mask has to give the pad.
    Hope this helps
    Jorge Garcia
    Cadsoft Computer
    Not addressed so far.
    When a package is created in the library and the pads are placed, the
    Solder Stop and Cream  setting can be set to On or Off (for automatically
    providing these layer shapes ,for each pad)
    When set on, the author of the package does not need to craft the Solder and
    Cream shapes on their respective layers.This is done automatically by Eagle
    and the DRC does control the final size.
    When set off the author needs to create each of the SolderStop and Cream
    shapes and place them over the pads. These ones do not change size with DRC
    settings.
    Yours will be made this way. So you have the choice of editing them all
    individually so they cover the pads or delete what has been created on these
    layers and then turn On the Stop and Cream for each pad On so the DRC
    controls the sizes.
    Warren
    Hi John,
    Hope this helps
    Jorge Garcia
    Cadsoft Computer
