EAGLE User Chat (English) re:PDF file output (5.8)
  • Subscribers 178 subscribers
  • Views 429 views
Former Member over 15 years ago
Hi Everyone,
My editors require PDF file submissions of my schematics. Is there any way
to do this in Eagle?
Rob
    autodeskguest over 15 years ago
    Am 25.04.2010 18:45, schrieb Rob:
    Hi Everyone,
    Rob
    Yes, file, print...
    then choose pdf as the printer image
    Gruß / regards
    Joern
    Rob wrote:
    Hi Everyone,
    In order to do what Joern already wrote you will need to install a PDF
    printer. I am using PDFCreator which works nicely with Eagle. I am doing
    the same thing like you, submitting some of my Eagle schematics as PDF.
    This program can also store other formats, not needed with Eagle because
    it can already export graphics but it is handy with software that
    doesn't have that capability.
    After installing this, you just print to the new PDF "printer". Instead
    of going to a real printer it will ask you what directory and file name
    you want for the PDF file.
    Regards, Joerg
    "Rob" <euclid@delhitel.net> wrote in message
    news:hr1rir$d0$1@cheetah.cadsoft.de...
    Hi Everyone,
    Rob
    FYI: I use the Eagle method and PDFcreator mentioned in earlier posts to
    produce PDFs, both work nicely. I did fine some differences. While the
    quality of the output appears identical, one produced a protrait PDF and the
    other a landscape PDF. Also PDFcreator produced a smaller sized PDF file.
    YMMV.
    It does work as Joern suggests and I sent an email to my other computer and
    the PDF looks fine.
    Rob
    "Greg Erskine" <gerskine@tpg.com.au> wrote in message
    news:hr2a91$lqp$1@cheetah.cadsoft.de...
    Hi Everyone,
    way to do this in Eagle?
    Rob
    the other a landscape PDF. Also PDFcreator produced a smaller sized PDF
    file. YMMV.
