EAGLE User Chat (English) Net list does not match gerber files
  • Subscribers 187 subscribers
  • Views 844 views
Hello
I am using IPC-D-356.ULP to output a net list that is sent to PCB house with
gerber files for board fabrication. And the board house is say that my net
list does not match my gerbers. Is anyone else using this ULP and getting
errors or maybe know of a better ULP for generating net list from eagle?
Jim Blain
    "Jim Blain" <jimblain@sunnuclear.com> wrote in message
    news:hr45us$17k$1@cheetah.cadsoft.de...
    Hello
    with gerber files for board fabrication. And the board house is say that
    my net list does not match my gerbers. Is anyone else using this ULP and
    getting errors or maybe know of a better ULP for generating net list from
    eagle?
    First, the factory should be able to pinpoint where the problems are.
    Second, I had to write my own cause this ulp could not handle long net and
    device names. Take a look at its output and check if all is arranged nicely
    into columns. If one line looks broken, that might be a problem.
    Also check your gerbers with a gerber viewer (like gerbv wich is freeware)
    to see if all layers and drills are aligned correctly. Some gerber viewers
    can import the netlist and show it's testpoints.
    It could be that the CAM processor is set to "pos. Coord", that it adds
    offsets that the IPC list does not have. You could ask the manufacturer to
    adjust for this offset.
    Jim Blain wrote:
    Hello
    Jim Blain
    I have used that ulp a few times w/o any negative feedback.   You might
    want to check to see if perhaps the CAM processing step is introducing
    some offset in the gerber data.   Perhaps your board house an also be a
    bit more explicit about what is wrong?
    Jim
