EAGLE User Chat (English) A little push?  (CNC,CAM,Milling) �ber newbie
  • Subscribers 178 subscribers
  • Views 408 views
Former Member over 15 years ago
Hi, i feel kind of a goof ball asking but
i want to use eagle to have my campus CNC router do my PCBs and ditch the
dreaded and temperamental ferric chloride.
but i came across lots of terms and information each saying " this is THE
method", can you  please point me in the right direction?
1)CAM and CNC milling/routing/drilling is the same, right?
2) there is apparently a " mill-outlines" script in EAGLE which generates
drill and mill files. if its that simple , why all the fuss and plethora of
formats?
(excellon, gerber,  G-Code, and a big Etcetera)
all the info i've see so far doesnt say why NOT  to use a format/method, i
need to know if its a choice or if it depends on something
3) cant i just export the drill fill/job and pop the circuit board in and
"presto!" ?
First experience with CNC , promise, next post will be actually insightful
and non-newbie .
    autodeskguest over 15 years ago
    formats?
    "presto!" ?
    and non-newbie .
    excellon and gerber are the formats used to drill and photoplot circuit
    boards by lithography. these files and any others in "manufacturing
    machine controlling" formats are referred to as "CAM files". they are
    not in the same format as native CAD files, hence there is a CAM
    processor which essentially reformats the vector drawing commands
    according to the output format.
    it doesn't really matter which format you use as long as it is correct
    for your milling machine and outputs outlines only. since milling a
    complex area only requires outlines, while photoplotting or laser
    printing requires fills or fills simulated with vectors, there is a
    difference in what is output in a mill outline file vs a gerber file
    aside from the formatting. the CAM processor is likely used for both
    conversions - however, the difference is what kinds of jobs you feed it.
    an EAGLE CAM job has sections that correspond to each process/ machine.
    for instance the top layer of circuit board etch will typically be made
    by plotting the layers top, pads and vias because all are part of the
    resist pattern for the top copper layer. this will be output as a single
    file.
    bottom line: use an outline program ( i think it's a ULP not a script)
    to generate the mill outlines for the 2 copper surfaces. fro the holes:
    i don't know if you can mill the holes in separate file or include them,
    since the depth will change, probably you need a separate control file.
    and you should study the use of the CAM processor to get familiar with
    the terminology and how it works.
    formats?
    "presto!" ?
    and non-newbie .
    Hi Luis,
    Gary covered most of your questions very eloquently, and he is correct I
    would just like to add a couple of points.
    For question 2, the format used is dependent on the machine. Many CNC
    machines use the G-code file format so in order to produce you board you
    would run the appropriate ulp (There's a good one up on the site
    gcode-1). The output file can then be used to program the machine at
    your school, afterwards it's pop in circuit board, PUSH BUTTON, then presto!
    In all seriousness, the method you use will depend on the capabilities
    and design of the machine at your school so you need to figure those
    details out first. Once you know what the machine needs you can generate
    the appropriate files and generate your board.
    Hope this helps,
    Jorge Garcia
    Cadsoft Computer
    http://millpcbs.com for how to use eagle to mill pcbs.
    "LuisMa" <luisma.suarez@hotmail.com> wrote in message
    news:hrq8lp$6fp$1@cheetah.cadsoft.de...
    of formats?
    "presto!" ?
    and non-newbie .
