EAGLE User Chat (English) How to derive multiple PCBs from a single   schematic?
  • Subscribers 189 subscribers
  • Views 641 views
If ignorance is bliss, I'm in heaven image
I am familiar enough with Eagle to have now designed several circuits with
PCBs and have had the PCBs made, and to my great relief, they actually
work.
I have a couple of more complex projects now, and I need to layout several
separate PCBs based on different parts of one schematic. I want to keep the
circuit as one schematic linking to three or four PCBs so I can make use of
ERC and DRC checks.
Essentially, I will have the main circuit and then satellite boards with
pots, leds, and maybe some jacks. The boards might be connected with flying
wires or with some type of connector
I have been unable to find this topic on the boards, and can't seem to find
any advice in the user manual.
Am I left with splitting the circuit into several parts and pasting them
into new schematics with their own PCB or can I leave the schematic as a
whole and somehow coerce Eagle into letting me have several PCBs?
David
    e14 Contributor over 16 years ago in reply to dukepro
    Chuck Huber wrote on Mon, 24 May 2010 07:06
    On 05/20/2010 02:51 AM, Tilmann Reh wrote:
    with
    flying
    Your options:
    a) Have one single schematic, and one board file containing the
    whole
    circuit.
    b) Split your schematic to reflect the functional units, and work
    separately on every functional unit.
    Good morning, David,
    Tilmann has some pretty good ideas.  I'd like to add to his in
    pointint
    out that there is an easy way to work around this on linux/mac
    systems:
    Add hard links to your schematic file.
    Suppose you have: circuit.sch and circuit.brd.
    shell> ln circuit.sch circuit-subsys1.sch
    shell> ln circuit.sch circuit-subsys2.sch
    You now have multiple file names that all reference the same file.  In
    eagle you can create one board for each file name.  If you want to
    start
    with the board you already have, try:
    shell> cp circuit.brd circuit-subsys1.brd
    shell> cp circuit.brd circuit-subsys2.brd
    This does not come without a warning, though.  If you modify the
    schematic, then it becomes inconsistent with all boards except the
    board
    you have open requiring prolific use of "erc".  I would consider this
    method only after you have nailed down your schematic.
    Enjoy,
        - Chuck
    Thanks Chuck.
    David
  • dukepro
    dukepro over 16 years ago in reply to autodeskguest
    Your options:
    a) Have one single schematic, and one board file containing the whole
    circuit.
    Tilmann has some pretty good ideas.  I'd like to add to his in pointint
    out that there is an easy way to work around this on linux/mac systems:
    eagle you can create one board for each file name.  If you want to start
    schematic, then it becomes inconsistent with all boards except the board
    Enjoy,
        - Chuck
    e14 Contributor over 16 years ago in reply to autodeskguest
    Tilmann Reh wrote on Thu, 20 May 2010 00:51
    several
    keep the
    make use of
    ERC and DRC checks.
    That is not possible with EAGLE. There is a strict 1:1 relation
    between
    schematic and board.
    with
    with flying
    to find
    them
    as a
    Your options:
    circuit. If it's divided in functional parts for which you want single
    boards, draw them side by side in the (single) board file. Provided
    you
    set proper distances between them, you might use that directly for
    producing them as a "panel". Take care about signal names to avoid
    unwanted airwires between the single boards.
    separately on every functional unit. You get as many schematics as you
    have boards (or vice versa).
    c) Combine a) and b) according to your preferences.
    Tilmann
    Thanks Tilmann. I can work with this.
    David
    ERC and DRC checks.
    That is not possible with EAGLE. There is a strict 1:1 relation between
    Your options:
    boards, draw them side by side in the (single) board file. Provided you
    Tilmann
