EAGLE User Chat (English) Re: Ground plane polygon pouring
  • Subscribers 187 subscribers
  • Views 333 views
Because I had done few boards since upgrading to EAGLE 5.8, I thought of
the radical idea of reading the manual to catch up with any new tricks.
That is when I followed the tutorial method for polygon pouring and ran
into troubles.  The missing linkages can be subtle and easily missed if you
just believe in the tutorial.
I think you are confirming the tutorial is wrong.  Sad as most people trust
such tutorials.
Cheers
Brian
    such tutorials.
    Cheers
    Brian
    Are you trying to say that you found a bug in the polygon pour? What
    manual and tutorial are you referring to anyway? And what are missing
    "linkages" ?
