EAGLE User Chat (English) Newbie with Eagle 6.3 Pro
  • Subscribers 187 subscribers
  • Views 189 views
Hi everyone.  I'm new to using Eagle and just designed a very simple breakout board allowing a user to connect CAT5e wires to some terminals on a PCB and then plug in patch cables to RJ45 modular jacks I placed on the PCB.  The only routes are from the connectors to the jacks - no electronics, etc..  When I was all done with the schematic, I placed the parts on the board.  I then used RatsNest to shorten any distances, but there was no change and then I used AutoRoute.  It routed 6 of the 8 connections (48 runs out of 64).  The remaining runs are still yellow wires - not traced.  Why is this?  I don't see any errors.  I tried removing a connector or 2 thinking there was some limitation, but they still did not trace when I selected auto-route.
Any help or suggestions would be greatly appreciated.
Kindest Regards,
DataCrypt
