EAGLE User Chat (English) Where are the 74ALS parts?
  • Replies 10 replies
  • Views 1708 views
I'm trying to find the following parts:
74ALS645D
74ALS08D
They don't seem to be in the default libraries nor in any downloadable
libraries I've found.
L.
    autodeskguest over 11 years ago in reply to autodeskguest
    On 14/06/2015 07:48, warrenbrayshaw wrote:
    On 14/06/2015 9:10 a.m., Logyx wrote:
    On 13/06/2015 16:57, Rob Pearce wrote:
    The better way to search for devices is to be in the Schematic and
    perform an ADD there. In the lower portion of the ADD dialog you can
    search. Wild cards work here. See the HELP.
    So search for 7408*
    or 74LS08
    You will see a couple of libraries have 74LS08N (DIL14)
    Again with 74645*
    Finds 74645N (DIL20)
    That worked a whole lot better!
    Yes, I've always been using the search function when in the "Add" tool
    in the schematic (I didn't know there were other ways to search for
    parts), but didn't know about the "*" wildcard.
    How does the "attributes" function work while searching?
    You can expect the footprint and gates of the 74ALS645D to be the same
    as the 74645N, but do verify that using the data sheets.
    As always you must verify the library parts before using them no matter
    where you source them from and that includes those that come with Eagle.
    Good idea! Thanks.
    On 13/06/2015 12:53, Olin Lathrop wrote:
    Logyx wrote on Sat, 13 June 2015 04:08
    74ALS645D
    74ALS08D
    So go make them.  By time you look around for them, post a question here
    about them, possibly find them somewhere, vet them, and maybe update them
    to your conventions, you'd have finished making them exactly as you want
    them.
    I did eventually locate a 74645N (from the "74ttl-din" library).
    If I do create a part (or copy and modify from another part), do I need
    to include all the gates etc. or will it do fine just to create have the
    IC rectangle shape with pins that are joined with the package outline?
    74ALS645D
    74ALS08D
    Have you looked in 74xx-eu.lbr (in the standard distribution)? It
    certainly has one of those.
    Yes, found the "08" there (not 74ALS645D though)!
    Maybe I'm not using the search function in Eagle's "Add" tool, but that
    library had them indexed as 74*08 so no wonder searching for 74ALS08D
    didn't work.
    Is there a smarter way to search for any and all variations of the 74LS08?
    L.
    Hi
    So search for 7408*
    or 74LS08
    Again with 74645*
    HTH
    Warren
  • e14candies
    e14candies over 11 years ago
    The project I want to do comes from a magazine from around 1987
    I also have a few project from then that I need to blow the dust off &
    finish up.
  • e14candies
    Is the difference between the various types within a specific TTL part
    Sure, speed, power and often most importantly, voltage trip levels (such as
    74LS08 vs cmos 74HC08 vs 74HCT08) differ.  Unless your app is very
    critical, most speed & power versions will just "drop in".  Of course HC &
    HCT are not TTL, they are CMOS & TTL compatible CMOS devices.
    Note the "D" is just one mfg suffix for "DIP" package...others may use
    something other than "D"
    RCA invented CMOS, but called it COS/MOS
    You can search for 7408* , since some companies also put letters in
    front, because alphabet soup is good for you.
    autodeskguest over 11 years ago in reply to e14candies
    On 13/06/2015 22:10, Hoyt wrote:
    74ALS645D is almost completely obsolete...you should use something else, or
    at least investigate a source before you commit & order boards (for parts
    that will never arrive).
    the non-D part is in stock in a few flavors
    Thanks for pointing this out. The project I want to do comes from a
    magazine from around 1987.
    (i.e. all variations of the 74_645) to do with how much power it draws
    and package type? In other words, provided there's enough power
    available, all variations would work?
    L.
    74ALS645D
    74ALS08D
    didn't work.
    L.
  • e14candies
    74ALS645D
    74ALS08D
    74ALS645D
    74ALS08D
    them.
