EAGLE User Chat (English) Eagle part for rubber keypad?
  • Answers 2 answers
  • Subscribers 189 subscribers
  • Views 2531 views
  • keypad
pschalkx
pschalkx over 11 years ago
Hi all,
I need to make a pcb to place under a rubber keypad, the usual type with a conductive pad under the dome of each key.
After some time searching I can't find an eagle part that does the job. I can sit down and create one myself, but why reinvent the wheel?
Does anybody know the name of a library and part to make the keypads?
Thanks in advance
Philip
    Philip Schalkx wrote on Tue, 28 July 2015 16:52
    Because it's faster than carefully vetting someone else's part to your
    design rules and conventions, then making the inevitable modifications.
    On 29/07/2015 8:52 a.m., Philip Schalkx wrote:
    Hi all,
    Thanks in advance
    Philip
    http://www.element14.com/community/message/156421
    Find the file attached in this post
    http://www.eaglecentral.ca/forums/index.php/m/160970/4d6b5fc3fba92534bcf97593f3cd846d/?srch=finger#page_top
    Warren
    0 autodeskguest over 11 years ago in reply to pschalkx
    On 31/07/2015 8:49 a.m., Philip Schalkx wrote:
    Hi Clem,
    Yes, I had noticed this one. But when I try to load the files into Eagle
    7.3 it complains that these are not eagle files. I opened them with a
    text editor and they are for Eagle version 6.x.
    Any suggestions?
    Tks!
    Philip
    http://www.element14.com/community/message/156635
    Hi
    The file is fine in version 7
    The issue is getting it out of github
    One way you get an HTML file
    Another way you get the library file with stuff on the front and more on
    the end.
    Try this way:
    From the link click Adafruit Trellis.lbr
    Then click RAW
    Then copy what you see into a file and save it as Adafruit Trellis.lbr
    Then open the file in Eagle.
    HTH
    Warren
  • clem57
    0 clem57 over 11 years ago in reply to pschalkx
    http://www.cadsoftusa.com/fileadmin/journalist/Documents/release_notes_v7.3_en.pdf
    Some help but no complete answers.
  • pschalkx
    0 pschalkx over 11 years ago in reply to clem57
    Hi Clem,
    Yes, I had noticed this one. But when I try to load the files into Eagle 7.3 it complains that these are not eagle files. I opened them with a text editor and they are for Eagle version 6.x.
    Any suggestions?
    Tks!
    Philip
  • clem57
    Have you seen this https://github.com/adafruit/Adafruit_Trellis
    C
