EAGLE User Chat (English) How can I generate a parts placement diagram?
  • Subscribers 187 subscribers
  • Views 846 views
I would like to publish parts placement diagrams like this to make stuffing easier. (This diagram was made by Ray Wilson / MusicFromOuterSpace.com)
    If you'd like to, then go ahead!
    OK, I know, you intended to also say "but I don't know how, could
    somebody tell me?"
    It's simple. That diagram consists of copper traces in light green and
    component outlines plus text in black. On Eagle, the copper is in layers
    1 to 16 (just 16 in the case of a single-sided through-hole board like
    that one) while the component outlines are in layer 21 ("tPlace") and
    the text in layers 25 (tNames), 27 (tValues), 51 (tDocu) and possibly
    others, but those are the most likely. You may also want layer 20
    (Dimension) for the board outline.
    So, in the board editor, click on the "Display" icon. Now deselect all
    except the ones you want. Double click on each of them and click the
    "Color" box. Pick the colours you want (e.g. pale green for 16, black
    for all others). Click "OK" on the Display dialogue.
    Your board editor will now be showing the diagram you want. You can use
    "File>Export... >Image" to create a diagram in PNG or similar. or you
    can print to a PDF.
    It's also possible to do something equivalent as a CAM job.
