EAGLE User Chat (English) Eagle part for 0603 EMIFIL
  • Views 658 views
  • eagle
  • part
  • emifil
Hi everyone,
I am pretty new to Eagle and electronic design and I am looking for the following part in Eagle:
http://www.digikey.com/product-detail/en/NFM18PC104R1C3D/490-6969-1-ND/3846166
Another part but with the same package is of course equally good.
Best,
Carl
    Carl Olsson wrote on Thu, 17 December 2015 08:32
    the
    166
    That's a particularly simple part to make.  It would have taken less time
    to make it than look for a freebie, ask here, and then have to vet the part
    anyway.  And now you probably still have to make it.
    0 e14 Contributor over 10 years ago in reply to shabaz
    Thank you for the quick answer!
    I am designing a module powered over the CAN bus and I need this part.
    Previously I have been creating my parts from other with the same package, but I have not seen a 0603 component before with three connections so I thought that it would be best not to create the package myself. But maybe I will have to do it anyway and hope that I will do it correct.
    0 shabaz over 10 years ago
    That's a bit of a specialist part for someone new to electronics design as you described yourself, are you sure you need that? What are you creating?
    Anyway, ordinarily you would create your own package and symbol within EAGLE, and combine them to produce your device. It is in the EAGLE user documentation how to do this.
    You'd get the dimensions from the part datasheet.
    The pre-created parts in EAGLE are really only for a small percentage of parts out there, so more often than not you will be creating your own with EAGLE or any other software tool.
    EDIT: link to the user documentation: Manuals & Books | CadSoft EAGLE PCB Design Software
