EAGLE User Chat (English) Unable to delete certain object.
  • Replies 20 replies
  • Subscribers 189 subscribers
  • Views 5591 views
  • eagle pcb
methias
methias over 9 years ago
Hi, I'm a new user of EAGLE. I'm trying to use EAGLE to design a PCB with Arduino Mega 2560 with some sensors. So the only thing I need for the design is the exact pin spacings and some elementary design with connectors.
So what I'm doing is I downloaded the EAGLE file from Arduino website, then I deleted any components that I do not want from the original file, only leaving the pad for the pin spacing. However, when I tried to delete an object from the top layer, which has some connections for it's microcontroller, no matter how I clicked the it, it wouldn't be deleted. Thus if I were to fabricate it, I would assume there would be connections that I do not want that will be printed(?)
Here's a capture of the layers I have, top layer is the one I want to remove.
https://s23.postimg.org/5x2mnpmwb/Capture.png
    0 autodeskguest over 9 years ago in reply to rachaelp
    On 10/01/2017 9:16 p.m., Rachael wrote:
    Rob Pearce wrote on Tue, 10 January 2017 07:57
    On 10/01/17 02:29, Aaron Qwe wrote:
    I actually have one more question, referring to what I want to do.
    Do I use holes or drills if what I want to do is just introduce some
    connectors and make connection to to the I/O pins?
    From my understanding I would need to use drills right?
    No.
    Rachael has helped you achieve what you were trying to do but I note
    Markus gave the rather more significant advice that you're probably
    trying to do the wrong thing. I'm still not entirely clear on what
    your
    "end goal" is, but I think you're trying to create a template for
    designing shield boards? If so...
    I'm in complete agreement with Rob and Markus here, it's probably not the
    best approach as, in the process of doing what you have done, you have
    ended up with a board which is the right shape with all the connectors on
    it but it's lost the detail of what the pinout of the connectors is so
    you'll have to look up on the actual Arduino pinout every time to make sure
    you connect things to the right place. It's definitely not the ideal
    solution. Using an Arduino library component to provide the starting point
    of your shield, all the information which enables mapping of functions to
    the correct pins on the connectors is retained.
    Best Regards,
    Rachael
    Just to remind others following this thread, now that the OP has the
    board outline and connectors, they could run the ULP
    'make-group2pac.ulp' to make the package for the library.
    HTH
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
  • rachaelp
    0 rachaelp over 9 years ago in reply to autodeskguest
    No.
    your
    Best Regards,
    Rachael
    http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
    0 autodeskguest over 9 years ago in reply to methias
    I actually have one more question, referring to what I want to do. Do I use holes or drills if what I want to do is just introduce some connectors and make connection to to the I/O pins?
    No.
    trying to do the wrong thing. I'm still not entirely clear on what your
    Editing an existing Arduino (host) design to get a minimal board is the
    wrong approach. What you ideally want is an Arduino shield pin-out as a
    library component. This component would have the signal names of the
    Arduino as pins on the schematic symbol, and a PCB package consisting of
    holes for the mounting holes and through-hole-pads for the header pins.
    Then, for each new shield you design, just drop one of these into the
    schematic along with all your other components, wire it up, and the
    board will have a template complete with all the air wires.
    There are a few of these knocking about, including the one Markus linked
    to. But to be honest, I designed one from scratch (for the CooCox
    "Embedded Pi" but it's much the same) using measurements from Google
    searches, and the whole process took less time than this discussion thread.
  • rachaelp
    0 rachaelp over 9 years ago in reply to methias
    Hi Aaron,
    It sounds like what you are describing there is plated through holes which in EAGLE can be done in the board by adding a via with a large drill size setting and giving it an appropriate name to match the net it is to connect with. Alternatively (and a better way to do it) you can create a library part for plated holes with various hole sizes specified in the part. You place this in your schematic and wire it to wherever you need and then the pads and air wires will show in the board so you can place it where you need and route it.
    But do you want plated through holes or do you want to place a part for a specific connector you wish to add? Again, a component can be created and then this will be added in the schematic and wired up, and will then appear in the board to be placed and routed.
    Let me know what you are trying to do and I will give you more specific help if you need it.
    Best Regards,
    Rachael
  • methias
    0 methias over 9 years ago in reply to rachaelp
    Yes, it is exactly as you said. I tried clicking way further than the origin. Thanks for the help!
  • rachaelp
    I decided it would just be easier to do it for you as it was only a 2 minute job to clear everything out and zip it up. See the attached......
    Arduino Blank.zip
  • rachaelp
    That's really odd as it deletes fine for me. Are you sure you are clicking near to the origin of the symbol which in this case is right in the middle of the symbol. I get the "boing" sound if I try to click too far away from the origin.
  • methias
    Yeap, I tried doing that from the schematics, but all I get is a "blank" sound notification. I cant select the ATMEGA whatsoever or do anything with it.
  • methias
    0 methias over 9 years ago in reply to autodeskguest
    Definitely would look into it! Thanks
  • rachaelp
    So you just want to make a generic board template on which to base your own board which will will plug into an Arduino?
    If that's the case just delete the ATMEGA2560 from the schematics, nothing you have said gives any reason for it still to be there as far as i can see.
