EAGLE User Chat (English) Eagle schematic: HELP a student
  • Subscribers 189 subscribers
  • Views 1248 views
  • eagle 8
  • eagle schematic
avv
avv over 9 years ago
I can't seem to find a BT157 triac in Eagle. Is it okay if I use BT138 instead?
Also, what element should I use for the transformer and dimmer control (potentiometers)??
  • clem57
    0 clem57 over 9 years ago
    Maybe a look at https://www.youtube.com/watch?v=qP6x0-QA45U will help you understand about libraries.
  • geralds
    0 geralds over 9 years ago in reply to avv
    in triac.lbr
    I created for you.
    Just drag and drop the BT157 in horizontal or vertical mounting.
    The selecting the transformer is not easy at first.
    First look for by properties, then by distributor where you can get it.
    triac.zip
  • avv
    0 avv over 9 years ago in reply to geralds
    Which element in particular??
  • avv
  • geralds
    for the TRIAC - yes you can use it. Just rename it to BT157 in the schematic.
    If you like to make a BT157, just create a device BT157 and copy from BT138 the symbol and part to the device.
    The two devices comes from the same family.
    The transformer is an PCB mounted transformer.
    But look for that, that the schematic is very old. So look for an transformer what you get today - security capsulated transformer .
    The lamp is an 12V [halogen] lamp (e.g. like from automotive, or 12V household spot lamps) with defined power.
    The potentiometers are normally linear potentiometers but with plastic shaft.
    Gerald
