Hi All,
just wondering does anyone out there know how to convert Footprint/Symbol of ASCII Format to CAD tool format such as EAGLE, Altium and PADs.
Appreciate anyone who can enlighten me.
Cheers
Edmund
Hi All,
Cheers
Edmund
The Power PCB (or Pads) can support ASCII format lib file.
using "Import ..." in Power PCB software
Matt Collinge wrote on Sun, 24 October 2010 22:28
and PADs.
There is no such thing as a standard "ASCII format" for a footprint or
symbol. Various packages have their own format, some of which can be
exported/imported to/from some kind of ASCII format. For example, Eagle
can export most things to a script file. So I guess the answer to your
question is you look at the documentation for whatever ASCII format you
have, and write a program that reads it and writes out the same information
in as a Eagle script.
The real question is apparently how to make a package and a symbol.
You look in the datasheet for the package dimensions and make the Eagle
package accordingly. Take into account the worst case outer edges of each
pin and leave a little slop. I like to leave 20 mil past the maximum end
of the pin to make manual soldering easier should I need to use a iron.
The sideways slop should be less. Generally you don't want the pad width
to exceed half the pin stride. You have to do a few calculations from the
datasheet information, but overall the process is pretty easy. Personally
I don't even look at the suggested footprint from the manufacturer. It
would take longer to check whether they followed my conventions than to
just make my own. Again, this is easy.
As for the schematic symbol, this is partly a matter of personal taste,
although there are definitely good and bad symbols. I like my schematics
to be neat and readable, so am willing to spend a little time to make the
symbol nice and clear and as meaningful to how it will be used in the
circuit as possible. Lazy people (and most manufacturers) just draw a IC
as viewed from the top with the schematic connection in package pin order.
That may save a few minutes making the symbol once, but will cost in
decipering time and confusion many times thereafter.
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
