EAGLE User Chat (English) How to get new components on the PCB ???
  • Views 502 views
I have a schematic (A) witch board (B) I want to fit exactly to the spot of the holes for some components from another schematic - therefor I have copied the BOARD from this other schematic to my project and want to use it as the board B.
Of cause I have to delete all the wiring and most of the components but LEAVE the components I want to fit to.
Now I have the problem when I switch to board, that the components from the schematic A is NOT to find at the board (B) - how can I some kind of "update", so that the components from A is to find on the board B ?
Best regards
KSOr, Denmark
  • Oliver
    0 Oliver over 14 years ago
    It is easy to create Libraries from Schematic and Board file by using ULP:exp-project-lbr.ulp from ULP folder in the path of EAGLE installation.
    board B ?
    Eagle cannot do this simply.
    How you proceed will depend on the number of objects you wish to place
    precisely.
    If you wish to replicate the board outline, a few mounting holes and the
    accurate placement of a few parts then I would do it manually using Eagle to
    deliver the precision.
    Right now your schematic(A) and Board(B) are consistent. All your actions
    need to retain that consistency.
    Proceed, as you have, open a copy of the reference BOARD that has the
    positioning you wish to replicate, removing all items that are not required.
    Next we can use a ULP to get the details/positioning of the remaining
    objects. Unfortunately there is no ULP to do the whole job.
    Use the ULP export-board.ulp (download from cadsoft.- caution this is a v4
    ULP but we can use it here for our purposes) The Script file that it creates
    has all the information you require but you cannot just run that script for
    a number of reasons.
    If you ran the scr file 'as is' it would draw the board outline and any
    mounting holes. It would then attempt to ADD (new)  the parts to the board
    and will fail due to naming or library issues.
    You need to modify the script to MOVE the equivalent board(B) part (your
    part) to the same location
    Open up the script file in a text editor.
    Change the lines that start ADD
    (1) Change ADD to MOVE
    (2) Delete all the way up to the "("
    So a line like
    ADD 'D1' D0204-10@diode R180.000 (0.400 2.650);
    becomes
    MOVE 'D1' (0.400 2.650);
    Next change the part name ('D1' in the above example) to match the part name
    on your schematic(A) Board(B) so you move the correct part into position.
    Save the script file
    Open your project (schematic(A) Board(B))
    Delete the default board outline on Board(B)
    Run the script file in the Board(B) editor
    You should see the board outline, holes and part placement of BOARD
    You may have to manually ROTATE a part to get it correct.
    You may care to LOCK those elements so you don't inadvertently move them
    later.
    In future when making daughter boards (Arduino shields are another example)
    Start with / prepare a (seed) project you copy  to be your current
    project.This has your board outline and connection headers done first.  Then
    you continue to develop the schematic. Another approach is to make this
    headers/board outline a library part.
    HTH
    Warren
    Viewed and responded to from the newsgroup at
    news.cadsoft.de
