EAGLE User Chat (English) custom pcb
  • Replies 8 replies
  • Answers 2 answers
  • Subscribers 189 subscribers
  • Views 917 views
custom pcb
Can you just design a pcb with holes only where you want them and with no component and wiring layout?  I just want to design a custom board.  Im placing the holes where I know my components will be at on the custom board.
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Marvin Dawson wrote on Thu, 27 October 2011 18:51
    We have had to add random mounting holes to the schematics, which is
    STUPID!
    Eagle isn't stupid.  What is stupid is people ranting about it without
    having read the documentation.
    You can add mounting holes directly to a board with the HOLE command.  You
    can even make more complex things, put them in a package in a library, then
    add the package to a board directly multiple times.  For example, I have
    pre-made packages for #4-40 mouting holes.  These include the hole and
    associated keepout areas.
    If on the other hand you want holes that are actually electrically
    connected to specific nets in the schematic, then of course these should be
    added to the schematic since they are part of the circuit.  You can make
    devices for these with all the details you want once, then add those
    devices multiple times to the schematic.  Then when you do the board, the
    mechanical part of these connection points will show up for you to place.
    This all makes sense when you stop and think about it.
    Quote:
    In our experience, only large vias can be added to be used as mounting
    holes when laying out a board, or having the designer add mounting hole
    parts to the schematic.
    Then your experience is limited and you need to read the documentation.
    Doug wrote:
    On 10/27/2011 3:51 PM, Marvin Dawson wrote:
    >> How can you add holes to a board?
    >> I always get a Warning about back-annotation not allowing it, and
    >> Eagle refuses to ADD.
    >> STUPID!
    >> mounting holes when laying out a board, or having the designer add
    >> mounting hole parts to the schematic.
    >> ~Marvin
    Eagle will refuse to add a pad, but will allow a hole to be added.
    Are you sure that you selected hole and not pad?
    Hmmm!  A few incorrect  words causing confusion.
    When in the board editor you can place a HOLE or a VIA. You cannot place a
    PAD. That action is limited to the library editor when building a package.
    The via icon looks like a pad but if you hover the mouse over it the tool
    tip says "Via".
    Vias are plated through and holes are generally not.
    You can add a VIA or a HOLE to a board at any time. This applies to a
    consistant schematic/board pair or a Board only design.
    Here I'm talking of adding a HOLE using the 'hole' icon or command in the
    board editor, not ADDing a hole from the hole library. If you attempt that
    you will get the back-annotation warning.
    You can ADD a hole from the hole library if the package there does not
    contain a pad. The presence of a pad implies a device exists for this
    package and hence a device must be added to the schematic and not just a
    package to the board..
    How you add a mounting hole to your board design depends on your design
    requirements and will be done as a VIA , HOLE or library part.
    HTH
    Warren
    news.cadsoft.de
    I always get a Warning about back-annotation not allowing it, and Eagle
    refuses to ADD.
    STUPID!
    ~Marvin
    0 e14 Contributor over 14 years ago in reply to Richard_H
    refuses to ADD.
    We have had to add random mounting holes to the schematics, which is STUPID!
    ~Marvin
    Richard Hammerl wrote:
    Am 26.10.2011 18:55, schrieb Willie Miner:
    >> custom board.
    You have the options to use Vias (drillings with copper ring around
    it) or Holes (used for mounting holes for example) and place it at
    any location.
    thank you
  • Richard_H
    0 Richard_H over 14 years ago
    any location.
    Richard Hammerl
    Use vias for the holes, and it should work fine.
  • MDeGrauw
    0 MDeGrauw over 14 years ago
    Hi Willie,
    As far as I am aware you can do this with the cadsoft eagle package provided by element14.
