EAGLE User Chat (English) connect vias
  • Views 506 views
connect vias
How do you connect vias on a pcb in eagle? example: i want three holes in a row to be connected. then three more holes connected in the next row. i will be soldering wires to the bottom of the pcb after looping them through from the top side. wires soldered in the same row will be electrically connected. thanks
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    thank you
    If you NAME the vias you want connected with the same name (really it's a
    signal name)  unrouted signal air-wires will automatically be drawn between
    them.
    Then you use ROUTE  to draw the trace on the top or bottom layer as
    required. You do need to read the manual (included in the .doc folder) and
    Help subjects to learn the intricacies. There are many tutorials to get you
    up to speed. It will be a long slow process learning by asking this level of
    question, one by one, here.
    All the best
    Warren
    news.cadsoft.de
